my name is rudi ;-) and i come from germany.
thank you espressif for open community.
hi guys
here is a first project,
nothing special but the famous hello world
at ready start and one new AT Command.
you can test it simple with
AT+;-)
- if you see a smilie - please be sure you have disable smilies for see the parameter
the base is the open sdk
download/file.php?id=1
i change a little in
at_cmd.h
at_baseCmd.h
at_baseCmd.c
Thank you Espressif!
Would be glad if the "new At Command" will be append in the next SDK Revisions as Base ;-)
this is fun ;-)
Best wishes!
rudi ;-)
edit: will change the version nr asap..
and append new ..asap
