TCP server Passthrough mode
mvandere
Postby mvandere » Tue Jul 07, 2015 2:20 pm
The manual implies that a single session TCP server can go into a UART-WIFI passthrough mode.
I can't seem to find the right combination of commands to make this happen.
Can you show me the commands necessary to set this up, with comments where needed?
Thanks,
Mark
Re: TCP server Passthrough mode
Postby ESP_Faye » Tue Jul 07, 2015 4:06 pm
Sorry that if ESP8266 works as TCP server,passthrough mode can not be enabled.
Only ESP8266 works as TCP client , or UDP transmission, in single connection mode, can enable passthrough mode.
Sorry for the inconvenience.
skatjus
Postby skatjus » Tue Apr 25, 2017 12:58 am
Did you find the answer about transparant mode ?
I try to send unknow amout of byte but it only work in client mode not in server mode...
We like very much to have TCP server Passthrough mode.
I try to use the 8266-01. Thanks if you have an answer.
