this is my code, for RTOS (I edit it because is long) Cellphone 1 is in port 3331 and cellphone 2 is in port 3332. if i send broadcast data from Cell 1 to 2 it never come. but if i send to ESP AP at port 3330, data arrives perfectly to ESP. I cant comunicate between clients.
What could be the error?
Thanks!!!
#include "esp_common.h"
#include "user_config.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/queue.h"
#include "espconn.h"
#define WIFI_APSSID "ESP8266"
#define WIFI_APPASSWORD "0123456789"
/*Definicion de datos de Sockets*/
#define SOCKET_PORT_IN 3330
#define SOCKET_PORT_OUT 6666
static struct espconn ptrespconn;
LOCAL void user_udp_recv(void *arg, char *rdata, unsigned short length)
//Do nothing for now...
void UDP_init(void)
ptrespconn.type = ESPCONN_UDP;
ptrespconn.proto.udp = (esp_udp *)os_zalloc(sizeof(esp_udp));
ptrespconn.proto.udp->local_port = SOCKET_PORT_IN;
espconn_regist_recvcb(&ptrespconn, user_udp_recv);
espconn_create(&ptrespconn);
void SetAP()
static struct softap_config apconf;
wifi_set_opmode(SOFTAP_MODE);
wifi_softap_get_config(&apconf);
memset(apconf.ssid, 0, 32);
memset(apconf.password, 0, 64);
memcpy(apconf.ssid,WIFI_APSSID, sizeof(WIFI_APSSID));
memcpy(apconf.password, WIFI_APPASSWORD, sizeof(WIFI_APPASSWORD));
apconf.authmode = AUTH_WPA_WPA2_PSK;
apconf.max_connection = 8;
apconf.ssid_hidden = 0;
apconf.ssid_len = strlen(WIFI_APSSID);
apconf.channel = 1;
apconf.beacon_interval = 100;
wifi_softap_set_config(&apconf);
uint32 user_rf_cal_sector_set(void)
flash_size_map size_map = system_get_flash_size_map();
uint32 rf_cal_sec = 4;
switch (size_map) {
rf_cal_sec = 128 - 5;
break;
rf_cal_sec = 256 - 5;
break;
rf_cal_sec = 512 - 5;
break;
rf_cal_sec = 1024 - 5;
break;
rf_cal_sec = 2048 - 5;
break;
rf_cal_sec = 4096 - 5;
break;
default:
rf_cal_sec = 0;
break;
return rf_cal_sec;
* FunctionName : user_init
* Parameters : none
* Returns : none
void user_init(void)
os_delay_us(500);
os_printf("SDK version : %s\n", system_get_sdk_version());
SetAP();
espconn_init(); //ESPCONN INIT
UDP_init();
