Static IP, specify netmask and gateway - wich AT version ?
hexor
Postby hexor » Fri Jul 10, 2015 1:57 am
Hello my friend,
I'm a little bit lost in the ESP8266's World.
Actually I use ESP8266 (esp01) whith this firmware:
AT+GMR
AT version:0.21.0.0
SDK version:0.9.5
I use them with DHCP, but now I must use with no DHCP so I must enter IP adress, netmask and gateway.
In AT 0.21, it's not possible to enter netmask and gateway, right ?
So, Which version I must use for specify netmask and gateway ?
Thanks a lot for your help ! ;)
Re: Static IP, specify netmask and gateway - wich AT version
Postby ESP_Faye » Fri Jul 10, 2015 10:06 am
At least AT_v0.22 based on SDK_v1.0.0 http://bbs.espressif.com/viewtopic.php?f=5&t=286
But we recommend to use the latest one, AT_v0.30 based on SDK_v1.2.0 http://bbs.espressif.com/viewtopic.php?f=5&t=680
Download the “esp_iot_sdk” and unzip it, "release_note.txt" shows the change list, AT bin files are in folder "bin", documentation in folder "document"
hexor
Postby hexor » Fri Jul 10, 2015 5:16 pm
Thanks a lot for your very fast answer !! :D
I have tried to upgrade my ESP8266 using "nodemcu firmware programmer", but it's not working. (il I try with my old sdk file, no problem, all is ok)
I have read the readme, but I had to make a mistake somewhere...
I have tested:
eagle.flash.bin      0x00000
eagle.irom0text.bin   0x40000
blank.bin      0x3e000 & 0x7e000
And also
boot_v1.2+.bin         0x00000
user1.1024.new.2.bin     0x01000
blank.bin              0x7e000 & 0xfe000
But nothing work, after upgrade I can't send AT command to my ESP (no response)
(And If I try to flash with my old version, no problem, I can send AT to the ESP)
Do you know where is my problem ?
Postby ESP_Faye » Mon Jul 13, 2015 11:32 am
Please use our official Flash download tool http://bbs.espressif.com/viewtopic.php?f=7&t=641
Documentation "4B-ESP8266__AT Command Examples" is in "\esp_iot_sdk\document"
If your problem is still unsolved, please offer the capture picture of Esp Flash download tool while downloading.
hexor
Postby hexor » Sat Jul 18, 2015 9:14 pm
Thanks all is working ! :D
