UDP : AT+CIPSTART ./. AT+CIPSERVER
User avatar
rudi
Postby rudi » Tue Dec 09, 2014 12:09 pm
Hi
i try to config one ESP8266ex as a UDP "server" but i think this is only possible as client to send UDP msg but not receive.
is there a choice with AT+CIPSTART and the UDP register run as a UDP device for incomming UDP msg?
perhabs this will be a nice doing in UDP as a "Server" / UDP device.
why:
with UDP broadcast message so all UDP devices can response the sending command with one command .. and at same time.
example
a remote RST
a remote Cloud update
a remote Home Automation example "Jalousie" close..open
a remote Home Automation example "Light out, Panik Light on.. ect ..
thank you for your instruction.
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
costaud
Re: UDP : AT+CIPSTART ./. AT+CIPSERVER
Postby costaud » Sun Dec 28, 2014 1:19 pm
Hey, I see your reply.
To the question, actually , the server in udp just means to register a receive port.
So in AT+ project , the process is :
AT+CWMODE=3//or other mode
AT+CWJAP="AP_SSID","AP_PASSWORD" //connect to ap or work as a softap
AT+CIPMUX=0 //single link, or multi
AT+CIPSTART="UDP","0",0,10000,2 //set udp local port , remote ip and port is irrespective until send data...
0,CONNECT
Then just send data via udp port you set ,(10000 in this case)
+IPD,14:broadcast test
+IPD,8:test udp
lucio.macellari.mac
Postby lucio.macellari.mac » Wed Nov 09, 2016 7:09 pm
the 8266 socket using AT commands seems to be unable to receive UDP broadcast datagrams.
The command:
does not setup the module to receive broadcast datagrams.
is impossible to achieve.
Someone can help?
