UDP socket connection problem
jenya7
Postby jenya7 » Tue Jun 29, 2021 7:25 pm
ESP-01 module and PC connected to the same AP.
ESP-01 module got - 172.16.1.153, PC got -172.16.1.128.
PC to ESP-01 - ping OK.
ESP-01 to PC - ping OK.
AT+PING="172.16.1.128"
+119
From PC side in Hercules open UDP - Module IP - 172.16.1.153, Port 1112, Local Port 8000 - Listen - UDP socket created.
ESP-01 module
AT+CIPSTART="UDP", "172.16.1.128", 8000, 1112, 2
IP ERROR
Why do I get an error?
Re: UDP socket connection problem
Postby Her Mary » Thu Aug 19, 2021 11:37 am
Which version are you using? Maybe you can have a try with the latest 8266 AT bin. https://docs.espressif.com/projects/esp ... index.html
