How to configure SoftAP with WPA2-PSK(AES) in non os sdk
maverickchongo
Postby maverickchongo » Wed Oct 06, 2021 4:06 am
Apple iOS is complaining about low security for my SoftAP which is using WPA2-PSK (TKIP), I believe it is because it is still using TKIP and I am trying to configure it with AES, the non-os-sdk documentation says that for the SoftAP AES is supported as well but I can't find any API to set it:
"ESP8266 softAP supports OPEN, WPAPSK, WPA2PSK; and encryption AUTO, TKIP, AES
are supported. But for the group key, only TKIP is supported."
Source:
https://www.espressif.com/sites/default ... nce_en.pdf
How can I configure it?
Ps. Migrating SDK is not an option for us right now.
Source:
maverickchongo
Re: How to configure SoftAP with WPA2-PSK(AES) in non os sdk
Postby maverickchongo » Fri Oct 08, 2021 5:08 pm
@Her Mary Correct, what I don't understand is why then the sdk guide says AES is supported for the soft AP?
Postby Her Mary » Tue Oct 19, 2021 3:09 pm
Maybe you should try RTOS instead: https://github.com/espressif/ESP8266_RT ... .c#L67-L71
AgentSmithers
- Contact:
Postby AgentSmithers » Thu Dec 09, 2021 5:14 pm
maverickchongo wrote:Hi,
Source:
This is what I use for my AccessPoint. I hope this points you in the correct direction
#ifndef __accesspoint__
#define __accesspoint__
//#define WifiMemorySpaceSector 0x51
#define WifiMemorySpace 0x63000//0x51000 //Also defined in station.h, make sure they match!
struct Customflashconfig APFlashStationConf;
bool ICACHE_FLASH_ATTR reset_accessPoint()
os_printf("[%s][%s][%d]\r\n", __FILE__ ,__func__, __LINE__);
struct Customflashconfig Tempconfig;
Tempconfig.programmed=0;
SpiFlashOpResult SpiReturn = spi_flash_write(WifiMemorySpace+sizeof(APFlashStationConf),(uint32 *)&Tempconfig,sizeof(Tempconfig));
if (SpiReturn == SPI_FLASH_RESULT_OK)
os_printf("Accesspoint programmed=0\r\n");
else
os_printf("Failed to reset Accesspoint\r\n");
bool ICACHE_FLASH_ATTR isset_accessPoint()
struct softap_config softapConfig;
spi_flash_read(WifiMemorySpace+sizeof(APFlashStationConf),(uint32 *)&APFlashStationConf,sizeof(APFlashStationConf));
if(APFlashStationConf.programmed==1)
return true;
else
return false;
typedef enum _auth_mode {
AUTH_OPEN = 0,
AUTH_WEP,
AUTH_WPA_PSK,
AUTH_WPA2_PSK,
AUTH_WPA_WPA2_PSK
} AUTH_MODE;
void ICACHE_FLASH_ATTR set_accessPoint(char * LSSID, char * LPassword, uint8 Lssid_len, AUTH_MODE Lauthmode, uint8 Lchannel, uint8 Lssid_hidden, uint8 Lmax_connection, uint16 Lbeacon_interval, char * LReserved)
os_memcpy(&Tempconfig.ssid, LSSID, 32);
os_memcpy(&Tempconfig.password, LPassword, 64);
Tempconfig.ssid_len=os_strlen(LSSID);
Tempconfig.authmode=Lauthmode;
Tempconfig.ssid_hidden=Lchannel;
Tempconfig.max_connection=Lmax_connection;
Tempconfig.beacon_interval=Lbeacon_interval;
wifi_softap_set_config(&Tempconfig);
Tempconfig.programmed=1;
//SpiFlashOpResult SpiReturn = spi_flash_erase_sector(WifiMemorySpaceSector);
SpiFlashOpResult SpiReturn = spi_flash_erase_sector(WifiMemorySpace/SPI_FLASH_SEC_SIZE);
os_printf("SPI Flash Erase OK\r\n");
os_printf("SPI Flash Write OK\r\n");
os_printf("ssid: \"%s\"\npw: \"%s\"\nProgrammed: %d\r\n",Tempconfig.ssid,Tempconfig.password,Tempconfig.programmed);
void ICACHE_FLASH_ATTR reload_accesspoint()
unload_accesspoint();
init_accesspoint();
void ICACHE_FLASH_ATTR unload_accesspoint()
os_printf("[%s] wifi_get_opmode() = %d\r\n", __func__, wifi_get_opmode());
if ((wifi_get_opmode() & 2) == 2)
wifi_set_opmode_current(wifi_get_opmode() & ~2);
os_printf("AccessPoint Disabled wifi_get_opmode() = %d\r\n", wifi_get_opmode());
void dhcps_lease_test(void)
struct ip_info info;
wifi_softap_dhcps_stop();
IP4_ADDR(&info.ip, 192, 168, 1, 1);
IP4_ADDR(&info.gw, 192, 168, 1, 1);
IP4_ADDR(&info.netmask, 255, 255, 255, 0);
wifi_set_ip_info(SOFTAP_IF, &info);
wifi_softap_dhcps_start();
struct dhcps_lease dhcp_lease;
IP4_ADDR(&dhcp_lease.start_ip, 192, 168, 1, 100);
IP4_ADDR(&dhcp_lease.end_ip, 192, 168, 1, 105);
wifi_softap_set_dhcps_lease(&dhcp_lease);
void ICACHE_FLASH_ATTR init_accesspoint(char * password, uint8 maxconnections)
//Need to implement APSSID And Password
if ((wifi_get_opmode() & 2) != 2)
os_printf("Loading AccessPoint %d -> %d\r\n", wifi_get_opmode(), (wifi_get_opmode() | 2));
wifi_set_opmode_current(wifi_get_opmode() | 2);
dhcps_lease_test();
os_printf("AccessPoint Loaded %d\r\n", wifi_get_opmode());
APFlashStationConf.ssid[31]=0;
APFlashStationConf.password[63]=0;
//wifi_set_opmode_current(WifiOpMode); //Need to add this to turn on AP
os_printf("Saved Information Found for AP!!\r\nssid: \"%s\"\npw: \"%s\"\n SizeOf(APFlashStationConf) = %d\r\n", APFlashStationConf.ssid, APFlashStationConf.password, sizeof(APFlashStationConf));
os_memcpy(&softapConfig.ssid, APFlashStationConf.ssid, 32);
os_memcpy(&softapConfig.password, APFlashStationConf.password, 64);
softapConfig.ssid_len=APFlashStationConf.ssid_len;
softapConfig.authmode=APFlashStationConf.authmode;
softapConfig.ssid_hidden=APFlashStationConf.ssid_hidden;
softapConfig.max_connection=APFlashStationConf.max_connection;
softapConfig.beacon_interval=APFlashStationConf.beacon_interval;
wifi_softap_set_config(&softapConfig);
else
os_printf("Saved Information Not Found for AP, Using Defaults!!\r\n");
//Set AP Settings
char APssid[32] = "ESP ";
char MACADDR[6];
wifi_get_macaddr(SOFTAP_IF, MACADDR);
char MACADDRFormatted[12];
os_sprintf(MACADDRFormatted,"%02x%02x%02x%02x%02x%02x", MACADDR[0], MACADDR[1], MACADDR[2], MACADDR[3], MACADDR[4], MACADDR[5]);
strcat(APssid, MACADDRFormatted);
//strcat(APssid, MAC2STR(bss_link->bssid))
//char APpassword[64] = "01234567"; //This should be defined by a function argument!!
char APpassword[64] = {0};
if (password != NULL)
softapConfig.authmode=AUTH_WPA_WPA2_PSK;
os_printf("Copying AP Password: %s\r\n", password);
os_strcpy(APpassword, password);
else
softapConfig.authmode=AUTH_OPEN;
os_printf("No AP Password specificied, Leaving AP Open\r\n");
os_memcpy(&softapConfig.ssid, APssid, 32);
//os_memcpy(&softapConfig.ssid, "bibo", 32);
os_memcpy(&softapConfig.password, APpassword, 64);
softapConfig.ssid_len=0;
softapConfig.ssid_hidden=0;
softapConfig.max_connection=maxconnections;
softapConfig.beacon_interval=100;
os_printf("Access Point Up - %s!!\r\n", &softapConfig.ssid); //APssid
else
os_printf("AP Already Loaded");
#endif
