user_rf_cal_sector_set and Espressif reserved flash sectors
Inquisitor
Contact:
Postby Inquisitor » Sun Nov 14, 2021 2:05 am
I've been inspecting the flash sectors reserved by the system...
(1) The 0 sector
(2) The last 4 sectors - on a 4MB board, this will be sectors 1020-1023.
When using a native, NonOS we need to expose something like this
uint32 ICACHE_FLASH_ATTR user_rf_cal_sector_set(void)
    uint32 rf_cal_sec = 0;
    switch (size_map) {
            rf_cal_sec = 128 - 5;
            break;
            rf_cal_sec = 256 - 5;
            break;
            rf_cal_sec = 512 - 5;
            break;
            rf_cal_sec = 1024 - 5;
            break;
            rf_cal_sec = 2048 - 5;
            break;
            rf_cal_sec = 4096 - 5;
            break;
        default:
            rf_cal_sec = 0;
            break;
    return rf_cal_sec;
Where it clearly puts rf cal stuff in sector -5 (the 5th sector from the end). Looking into the Arduino code base, Arduino appears to put it in sector -4 and use sector -5 for simulating the EEPROM.
uint32_t user_rf_cal_sector_set(void)
    spoof_init_data = true;
    return flashchip->chip_size/SPI_FLASH_SEC_SIZE - 4;
When I tried to use sector -4 in NonOS, I get continuous reboots. My questions are...
  1. What is user_rf_cal_sector_set() sector contain / used for?
  2. Why is it variable for us developers to place in the flash?
  3. Since its required why is it not just part of the 4 end sectors already reserved? They are sparsely used and seem like they could easily hold the data placed in this user_rf_cal_sector_set sector.
  4. Arduino seems to use this, but puts it in a place where it is reserved by Espressif.
  5. Where is the Arduino version putting it so it can use sector -5 for EEPROM?
https://InqOnThat.com
