236 kbyte limit on 4M flash?
eriksl
Postby eriksl » Tue Jul 21, 2015 5:36 pm
I am running into the problem that apparently my firmware is getting too large. There are no linker warnings, but the esp8266 simply won't start. No UART output as well, nothing. If I reduce the total firmware size (iram+irom) to exactly 236 kbyte, it works normally. Add a few bytes above the 236 kbyte, it fails.
Is this a know problem or is it normal behaviour, can it be fixed?
I do realise that at the point of flashing/storing the firmware all of the .text, .text_irom0, .rodata and .data sections must be stored into the flash. Is that the reason? My iram firmware file is 43 k (which apparently can fit in 32 k when run, no problems there, metadata?) and my irom firmware is 192 k now.
Re: 236 kbyte limit on 4M flash?
Postby ESP_Faye » Tue Jul 21, 2015 5:51 pm
1. What are your bin files, eagle.flash.bin + eagle.irom0text.bin , or user1.bin ?
Did you choose 4096KB in STEP5 while compiling ?
2. Do you add ICACHE_FLASH_ATTR before your functions ?
void ICACHE_FLASH_ATTR
user_esp_platform_init(void)
eriksl
Postby eriksl » Tue Jul 21, 2015 6:02 pm
Espressif_Faye wrote:1. What are your bin files, eagle.flash.bin + eagle.irom0text.bin , or user1.bin ?
The firmware files are "eagle.flash.bin + eagle.irom0text.bin" style.
The firmwares are made for 4M (256+256) layout, if you mean that.
If I would have forgotten that, I would have run out or iram very long ago. Almost every code is section .irom0.text. That is why this section/firmware ("eagle.irom0text.bin") is so large. This is NOT the problem. The problem is the .irom0.text (irom) section getting large, not the .text (iram) section. The linker script I can use 0x3c000 bytes (about 224 kbytes) and therefore it doesn't give an error. Still I can't make irom firmware files that are larger than 192 kbytes -> crash.
blubb
Postby blubb » Tue Jul 21, 2015 11:31 pm
Do you mean 4MBit or 4MByte...?
eriksl
Postby eriksl » Wed Jul 22, 2015 2:22 pm
blubb wrote:Do you mean 4MBit or 4MByte...?
4 Mbit of course. Flash memories are identified by their capacity in bits.
eriksl
Postby eriksl » Wed Jul 22, 2015 2:27 pm
I already solved the problem. I managed to use almost all of the 4 Mbits (c.q. 512 Mbyte) by adjusting the irom.text region to from 0x40000 to 0x10000. It's not at all clear to me why the supplied loader scripts have the irom.text region at 0x40000 which is halfway the memory.
My original problem was that during flashing the address wrapped around so the last bytes of the image would end up at the very start of the memory.
Users browsing this forum: No registered users and 29 guests
