Reboot occurred in system_upgrade_start() for FOTA
riverwin
Postby riverwin » Wed Jul 22, 2015 8:24 pm
I am using system_upgrade_start() functions for FOTA (Firmware upgrade over-the-air) using the binary files on my own OTA server.
Initially the upgrade process was successful, but it began to fail (reset occurred) to have repeated several times.
 ets Jan  8 2013,rst cause:4, boot mode:(3,0)
wdt reset
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
  SPI Speed      : 26.7MHz
  SPI Mode       : QIO
jump to run user2 @ 81000
I use SDK 1.2.0.
The size of the binary file for upgrade is 306272 Bytes.
Please confirm it.
Re: Reboot occurred in system_upgrade_start() for FOTA
Postby ESP_Faye » Fri Jul 24, 2015 10:47 am
Here is an example of FOTA http://bbs.espressif.com/viewtopic.php?f=7&t=423#p1619
If your problem is still unsolved, please offer your test code and we will have a try.
fvpalha
Postby fvpalha » Sat Sep 19, 2015 4:43 am
Hi riverwin,
Do you can share a example of FOTA firmware?
I want add this feature in my firmware.
