Memory Leak/Usage
Memory Leak/Usage
Postby zaxl » Thu Jul 23, 2015 4:41 pm
I'm using the memory optimized SDK 1.2.0.
The issue is that my tcp disconnect callback is not called and each accepted tcp connection leaks between 108 and 288 bytes.
/Will figure exact number but this is from a timer that runs every second to report free heap/.
Tried to set option REUSEADDR but does not make any difference.
I'm using code based on the esp_httpd .
init ....
espconn_regist_connectcb(&httpdConn, httpdConnectCb);
espconn_tcp_set_max_con_allow(&httpdConn, MAX_CONN);
espconn_set_opt(&httpdConn, ESPCONN_REUSEADDR);
espconn_accept(&httpdConn);
static void ICACHE_FLASH_ATTR httpdConnectCb(void *arg) {
espconn_regist_recvcb(conn, httpdRecvCb);
espconn_regist_reconcb(conn, httpdReconCb);
espconn_regist_disconcb(conn, httpdDisconCb);
espconn_regist_sentcb(conn, httpdSentCb);
I'm closing the connection from my main loop but httpdDisconCb is not called.
The incoming connection limit is a kind of useless - with 2 minutes timewait i can generate enough connections to trigger an out of memory condition. Connect/Close 200 bytes per connection about 100 connections and the device is OOM.
What is the way to deal with TCP memory in general?
Regards
zaxl
Re: Memory Leak/Usage
Postby ESP_Faye » Mon Aug 03, 2015 10:06 am
So sorry for the inconvenience. Could you provide your test code ? We will have a try.
If the TCP connection broke unexpected, httpdReconCb will be called.
If espconn_disconnect is called or normally TCP disconnect, it will enter httpdDisconCb.
Postby zaxl » Wed Aug 05, 2015 2:01 pm
I'm working on a test case code, i'll give it out when ready.
My code flow is like this:
1. listen on port 80 -> web server
2. outbound ssl connection to server. close connection
3. start normal connection to server - long lived
So far i found out that:
If there is only listen on port 80 -> disconnect callback is called - no leak
If there is outbound connection /don't know which one is causing the problem yet/ -> disconnect callback is not called and it leaks.
zaxl
Postby ESP_Faye » Sun Aug 09, 2015 8:52 am
Please have a try with the latest sdk_v1.3.0 http://bbs.espressif.com/viewtopic.php?f=46&t=918&p=3092
If your problem is still unsolved, please provide your test code. We will debug it.
mharizanov
Postby mharizanov » Mon Aug 10, 2015 2:28 pm
I tried with SDK 1.2 and 1.3 and it fails with both. It works just as expected with SDK 1.1
Postby ESP_Faye » Mon Aug 10, 2015 4:33 pm
Please update to esp_iot_sdk_v1.3.0 and try the SSL patch here http://bbs.espressif.com/viewtopic.php?f=46&t=925
Please have a try. If your problem is still unsolved, feel free to let us know !
mharizanov
Postby mharizanov » Tue Aug 11, 2015 1:17 am
SSL example
Postby hdrut » Wed Aug 12, 2015 12:33 am
I'm trying to implement the SSL example provided by Espressif, but get the following errors I can't debug:
undefined reference to `espconn_secure_sent'
undefined reference to `espconn_secure_connect'
Any help is appreciated.
Rgds
Re: SSL example
Postby rudi » Wed Aug 12, 2015 3:15 pm
hdrut wrote:Hi,
Rgds
think you simple forget "to add" the ssl lib in makefile?
example:
LIBS = c gcc hal phy pp net80211 lwip wpa upgrade main ssl
write please, how you get on in this.
best wishes
rudi
問候飛出去的朋友遍全球魯迪
Re: SSL example
Postby hdrut » Wed Aug 12, 2015 8:14 pm
yes! That was the problem, how silly of me
How are you doing? Have you managed to do some progress on copy protection for ESP?
I am now trying SSL communication, just started...
Cheers, i am going to celebrate my birthday today !!
Hope to hear from you soon, wish all is fine with you Rudi,
Horacio
rudi wrote:hdrut wrote:Hi,
Rgds
example:Code: Select all
best wishes
rudi
