ESP8266 Download Tool Parameter Discrepancy
jimyates
Postby jimyates » Fri Nov 03, 2017 12:49 am
I am trying to program the WROOM-02, but there is a discrepancy in between the configuration shown on boot of the wroom-02 and that shown by the ESP8266 download tool. When the wroom boots, listening to the UART at 74880 baud, I receive the following message:
ets Jan 8 2013,rst cause:1, boot mode:(3,6)
tail 0
chksum 0x63
tail 0
chksum 0x02
tail 0
chksum 0x79
csum 0x79
2nd boot version : 1.5
SPI Speed : 40MHz
SPI Mode : DIO
jump to run user1 @ 1000
rf cal sector: 249
rf[112] : 00
rf[113] : 00
rf[114] : 01
SDK ver: 1.5.4.1(39cb9a32) compiled @ Jul 1 2016 20:04:35
phy ver: 972, pp ver: 10.1
but when I run the ESP8266 download tool, the DETECTED INFO block shows:
flash vendor:
A1h : FM
flash devID:
4016h
QUAD;32Mbit
crystal:
26 Mhz
So which should I believe when programming the device?
Should I use DIO or QIO?
Should I use 8Mbit, or 32Mbit?
What addresses should I use for default.bin, blank.bin, user1 bin, and user2 bin?
Re: ESP8266 Download Tool Parameter Discrepancy
Postby ESP_Faye » Fri Nov 03, 2017 5:36 pm
8Mbit(512KB+512KB) is the flash map you selected on the ESP Flash Download Tool when downloading.
QUAD;32Mbit is the actual size of your flash.
So it means that you are using a 32Mbit flash as a 8Mbit flash.
You can select 32Mbit on the ESP Flash Download Tool when downloading to make full use of it.
