MODEM_SLEEP_T and system idle task
andrewtinkers
Postby andrewtinkers » Thu Nov 16, 2017 5:06 am
In the documentation, MODEM_SLEEP_T seems like a great way to keep the wifi connection alive, yet still saving power.
However, I see some indeterminate behavior:
Most of the time, after a http request, I see the modem turn off, and the current draw drops from ~60mA to ~15mA within a second. And then there are short keep-alive connections later. This is expected.
However, sometimes after the http request, the modem stays on for 5 seconds, 10 seconds, even minutes. What determines this? Is it because we haven't hit a system idle task yet? If so, is there a way to debug which task is executing and preventing the system idle task?
Thank you!
Thank you!
andrewtinkers
Re: MODEM_SLEEP_T and system idle task
Postby andrewtinkers » Fri Nov 17, 2017 1:27 am
I see it go into DTIM mode later actually. I attached a oscilloscope capture. There is a steady modem on period (RX I guess?) and then later it goes into DTIM, which is characterized by 15mA base, with 60mA spikes at a regular interval. I'm trying to figure out what the long 60mA bit is. This tail is always after a successful http transaction. And sometimes it is 500ms long, sometimes it can be as long as 10 seconds. I'm trying to figure out why, and how to make it consistent.
- Attachments
- long.png (8.74 KiB) Viewed 8696 times
andrewtinkers
Postby andrewtinkers » Fri Nov 17, 2017 10:19 am
Or, if it is really due to waiting for DTIM, is there a way to check, or to set a timeout? Or is this all in the sdk, and not accessible by developers?
Users browsing this forum: No registered users and 296 guests
