Difference exists between non-OS and OS version in the programming process.
[Non-OS Version]
Set the input mode to MTDO and configure it in falling edge trigger mode.
void ICACHE_FLASH_ATTR gpio_init(void)
PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U,FUNC_GPIO15); //GPIO Alternate Function
GPIO_DIS_OUTPUT(GPIO_ID_PIN(15)); //Configure it in input mode.
ETS_GPIO_INTR_DISABLE(); //Close the GPIO interrupt
ETS_GPIO_INTR_ATTACH(GPIO_INTERRUPT,NULL); //Register the interrupt function
gpio_pin_intr_state_set(GPIO_ID_PIN(15),GPIO_PIN_INTR_NEGEDGE); //Falling edge trigger
ETS_GPIO_INTR_ENABLE() ; //Enable the GPIO interrupt
}[OS Version]
GPIO_ConfigTypeDef gpio_in_cfg; //Define GPIO Init Structure
gpio_in_cfg.GPIO_IntrType = GPIO_PIN_INTR_NEGEDGE; //Falling edge trigger
gpio_in_cfg.GPIO_Mode = GPIO_Mode_Input; //Input mode
gpio_in_cfg.GPIO_Pin = GPIO_Pin_15; // Enable GPIO
gpio_config(&gpio_in_cfg); //Initialization function
GPIO_REG_WRITE(GPIO_STATUS_W1TC_ADDRESS, BIT(GPIO_UART_IN_NUM));
gpio_intr_handler_register(interrupt_GPIO_UART); // Register the interrupt function
_xt_isr_unmask(1 << ETS_GPIO_INUM); //Enable the GPIO interrupt
}[Configuration Instructions]
Please refer to "0D-ESP8266__Pin_List__Release_15-11-2014.xlsx" in the Documentation List of Development Guides.
- You can refer to GPIO alternate function registers in the Reg tabs.
- You can refer to GPIO and its multiplexing functions in the Digital Die Pin List tabs, during which the column of FUNCTION provides configuration options for functions.
Type 2 in the corresponding bit of the register if it’s needed to configure it in FUNCTION3; type 1 in the corresponding bit if it’s needed to configure it in FUNCTION2, and so on.
For example, in the code of PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDO_U,FUNC_GPIO15), the value of FUNC_GPIO15 is three and according to FUNCTION4 in the list, this means that PERIPHS_IO_MUX_MTDO_U is configured to GPIO function.
