NONOS_SDK里at_sdio例子
cheung
NONOS_SDK里at_sdio例子
Postby cheung » Thu Nov 23, 2017 3:43 pm
在sdio_slave_init里
 SET_PERI_REG_MASK(SLC_CONF0, SLC_RXLINK_RST|SLC_TXLINK_RST);
    CLEAR_PERI_REG_MASK(SLC_CONF0, SLC_RXLINK_RST|SLC_TXLINK_RST);
    os_printf("RX&TX link reset!\n");
    //set sdio mode
    SET_PERI_REG_MASK(SLC_RX_DSCR_CONF, SLC_RX_EOF_MODE | SLC_RX_FILL_MODE);
    //clear to host interrupt io signal for preventing from random initial signal.
    WRITE_PERI_REG(SLC_HOST_INTR_CLR, 0xffffffff);
    //enable 2 events to trigger the to host intr io
    SET_PERI_REG_MASK(SLC_HOST_INTR_ENA , SLC_HOST_TOHOST_BIT0_INT_ENA);
    ////initialize rx queue information
这段代码是在配置寄存器吗?在哪里可以找到这几个函数和参数的说明手册?
Re: NONOS_SDK里at_sdio例子
Postby Her Mary » Fri Nov 24, 2017 3:06 pm
是配置寄存器吧,定义在 eagle_soc.h,文档可以参考 ESP8266 技术参考。
Users browsing this forum: No registered users and 294 guests
