我的代码是基于SDK1.2.0编译的,还打了最新的patch。代码的逻辑是如果没有记录AP信息就自动开启Smartconfig,如果有记录AP信息则自动连接到相应的AP,我的客户端是用Airkiss协议的。当连接到AP成功后将自动通过一个UDP端口向服务器发送登录信息(24bytes),如果是通过Smartconfig连接成功(AP信息已被记录)的时候在调用espconn_sent时有可能会发生Fatal exception(9)错误并重启,如果通过记录的AP信息进行连接的话不论怎么也不会发生错误。重新烧录或清除AP记录信息后测试会产生这问题的机率挺高的,40%以上,但是我找不到什么合理的逻辑,只知道把调用espconn_sent那句注释了就一定没问题。可能是Smartconfig库对内存的使用有问题?希望能有人给个指引方向,谢谢!
附上错误打印信息和s文件部分信息:
Fatal exception (9):
epc1=0x4010532b, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000007, depc=0x00000000
UDPSend.h
typedef struct _SendInfo{
volatile unsigned int iValid;
volatile unsigned int iValidTime;
struct espconn *iConn;
SOCKIP iRemoteIP;
int iRemotePort;
int iLength;
char iBuffer[512];
}SendInfo;
user1.1024.new.2.S:
int sendTo(SendInfo *aInfo){
4010531c: f0c112 addi a1, a1, -16
4010531f: 21c9 s32i.n a12, a1, 8
40105321: 3109 s32i.n a0, a1, 12
40105323: 02cd mov.n a12, a2
if (aInfo && aInfo->iConn && aInfo->iConn->proto.udp){
40105325: b2ac beqz.n a2, 40105354 <sendTo+0x38>
40105327: 2228 l32i.n a2, a2, 8
40105329: 72ac beqz.n a2, 40105354 <sendTo+0x38>
4010532b: 2258 l32i.n a5, a2, 8
espconn_sent(aInfo->iConn, (unsigned char *)aInfo->iBuffer, (unsigned short)aInfo->iLength);
return aInfo->iLength;
return false;
4010532d: 020c movi.n a2, 0
4010532f: 211527 beq a5, a2, 40105354 <sendTo+0x38>
os_memcpy(aInfo->iConn->proto.udp->remote_ip, &aInfo->iRemoteIP, 4);
40105332: 3ccb addi.n a3, a12, 12
40105334: 440c movi.n a4, 4
40105336: 25cb addi.n a2, a5, 12
40105338: ec6601 l32r a0, 401004d0 <call_user_start_local+0x298>
4010533b: 0000c0 callx0 a0
aInfo->iConn->proto.udp->remote_port = aInfo->iRemotePort;
4010533e: 2c28 l32i.n a2, a12, 8
40105340: 4c58 l32i.n a5, a12, 16
40105342: 2238 l32i.n a3, a2, 8
40105344: 0a1c42 l16ui a4, a12, 20
40105347: 0359 s32i.n a5, a3, 0
40105349: 18cc32 addi a3, a12, 24
4010534c: fff301 l32r a0, 40105318 <isUDPInited+0xc>
4010534f: 0000c0 callx0 a0
40105352: 5c28 l32i.n a2, a12, 20
return false;
Fatal exception (9)
Re: Fatal exception (9)
Postby ESP_Faye » Mon Aug 03, 2015 10:24 am
您好,
您可以参考帖子 viewtopic.php?f=61&t=292
在 eagle.S 中查找您出错的地址,对应的是哪个函数。添加 log,进一步查证问题原因。
如果您的问题仍未解决,可以提供您的测试代码,我们将协助您一同查证。
