UART speed setting does take any effect
lcoulon
Postby lcoulon » Tue Dec 12, 2017 6:48 am
I upgraded a ESP12 32M with latest firmware : ESP8266_NONOS_SDK-2.1.0 , with AT binaries.
I tried to change UART speed to be 115200 Bauds with the following command :
AT+UART_DEF=115200,8,1,0,0
But it looks the module remains at 74880 Bauds,
If i enter the following connected at 74880 it continues to respond :
AT+UART_DEF?
+UART_DEF:115200,8,1,0,0
If i swap Putty or Hyperterminal at 115200, i get unreadable characters that means speed is incorrect.
I have set the terminal speed back to 74880 Baud to communicate with the module, this is not normal isn't it ?
Many thanks for your help,
Re: UART speed setting does take any effect
Postby Her Mary » Fri Dec 15, 2017 3:05 pm
Strange problem. Maybe you can use "AT+RESTORE" to initialize it first, and then test it again.
Trivenu
Postby Trivenu » Fri Dec 22, 2017 7:05 pm
Hi sir,
My code is working properly if i use default baudrate@115200.
If i change the baudrate to 460800 (or) 9600 then esp causes problem.i.e,
AT+UART_CUR=9600,8,1,0,0\r\n (or)AT+UART_CUR=460800,8,1,0,0\r\n
after set this command i get reply "OK" after this command i am sending
AT_CWMODE_CUR=1\r\n to esp through my controller...Then the esp is not replying any thing.....
if i use defalt baudrate (115200),everthing working fine..but when i change baud rate then it leads
to problem.....can you help me to solve this problem
Thanks in advance..
Postby Her Mary » Mon Dec 25, 2017 2:26 pm
Have you also changed the baud rate of your controller?
And you can use AT+UART_CUR? to read the configuration first, is RTS/CTS enabled?
