FCC sample code missing
someburner
Postby someburner » Sun Jan 07, 2018 9:14 am
http://espressif.com/en/support/explore ... ?keys=Test
Where is this? Can I obtain it for myself via private correspondance? We are about to beging compliance testing and I would like to not have to re-write this all myself. And yes, we do need to do this because we have a 2nd radio co-located next to the ESP. So modular cert does not cover this.
- iot-bits.com
- Contact:
Re: FCC sample code missing
Postby iot-bits.com » Mon Jan 08, 2018 5:57 pm
http://espressif.com/sites/default/file ... 170803.zip
someburner
Postby someburner » Wed Jan 10, 2018 4:16 pm
- iot-bits.com
- Contact:
Postby iot-bits.com » Wed Jan 10, 2018 5:13 pm
You should see what the support team tells you, they respond better if you contact via the Fb page.
Otherwise you have to write your own firmware there.
someburner
Postby someburner » Wed Jan 10, 2018 6:09 pm
someburner
Postby someburner » Thu Jan 18, 2018 1:58 pm
I have written a wrapper around their firmware. However it appears that the firmware uses a predefined init_data_default sector, which is problematic since they have updated init_data_default.bin to "v08" which contains slightly lowered Tx power levels. And the examples all use "0" as the 3rd parameter which I am assuming means "default". But what is the default? I believe it is the old v05. So then we should all be using param3 == 4 ?'
Come on guys. I know the ESP32 is your primary focus right now, but this kind of stuff only takes a few minutes to update..
Users browsing this forum: No registered users and 328 guests
