When I compile this sample code it's kicking off this error. Is there a Libary I am missing in my Makefile for UART to function?
Main.c
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "ip_addr.h"
#include "mem.h"
#include "user_interface.h"
#include "lwip/stats.h"
#include "espconn.h"
#include "c_types.h" ////ONE WIRE
#include "../library/uart.h" //Copy these from your Driver Lib to your local folder
#include "../library/gpio16.h" //Copy these from your Driver Lib to your local folder
#include "../library/common.h"
#define user_procTaskPrio 0
#define user_procTaskQueueLen 1
os_event_t user_procTaskQueue[user_procTaskQueueLen];
static const int LEDpin = 2; //LED
void uart0_tx_buffer(uint8 *buf, uint16 len);
LOCAL void uart0_rx_intr_handler(void *para)
os_printf(para);
void ICACHE_FLASH_ATTR sdk_init_done_cb(void)
os_printf("[%s] initializing ESP8266!\n", __func__);
uart0_tx_buffer("test", 4);
//uart1_sendStr_no_wait("test");
void ICACHE_FLASH_ATTR user_init()
//void uart0_tx_buffer(uint8 *buf, uint16 len)
wifi_set_opmode(0);
wifi_set_sleep_type( NONE_SLEEP_T );
ETS_GPIO_INTR_DISABLE();// Disable gpio interrupts
gpio_init();
SetAllGPIOPinsAsOutput();
/* Need to fix this to display value */
uint32 VDDADCByte[4] = {0};
spi_flash_read(0x3fc06b, (uint32 *)&VDDADCByte, 1); //Read pads the other 3 bytes with FF
os_printf("\r\n\r\nStarting ESP8266 OTA!\r\nSDK version:%s\r\nLoaded from: %02x\r\nVdd33_Const: %02x\r\n", system_get_sdk_version(), system_get_userbin_addr(), (VDDADCByte[0] & 0xff));
//Turn off LED
gpio_output_set((1 << 2), 0, 0, 0);
//Start os task
system_init_done_cb(sdk_init_done_cb);
//system_os_task(loop, user_procTaskPrio, user_procTaskQueue, user_procTaskQueueLen); //Task to Signal for later
Uart.h
* ESPRSSIF MIT License
* Copyright (c) 2016 <ESPRESSIF SYSTEMS (SHANGHAI) PTE LTD>
* Permission is hereby granted for use on ESPRESSIF SYSTEMS ESP8266 only, in which case,
* it is free of charge, to any person obtaining a copy of this software and associated
* documentation files (the "Software"), to deal in the Software without restriction, including
* without limitation the rights to use, copy, modify, merge, publish, distribute, sublicense,
* and/or sell copies of the Software, and to permit persons to whom the Software is furnished
* to do so, subject to the following conditions:
* The above copyright notice and this permission notice shall be included in all copies or
* substantial portions of the Software.
* THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
* IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS
* FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR
* COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER
* IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
* CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#ifndef UART_APP_H
#define UART_APP_H
#include "uart_register.h"
#include "eagle_soc.h"
#define UART_TX_BUFFER_SIZE 256 //Ring buffer length of tx buffer
#define UART_RX_BUFFER_SIZE 256 //Ring buffer length of rx buffer
#define UART_BUFF_EN 0 //use uart buffer , FOR UART0
#define UART_SELFTEST 0 //set 1:enable the loop test demo for uart buffer, FOR UART0
#define UART_HW_RTS 0 //set 1: enable uart hw flow control RTS, PIN MTDO, FOR UART0
#define UART_HW_CTS 0 //set1: enable uart hw flow contrl CTS , PIN MTCK, FOR UART0
#define UART0 0
#define UART1 1
typedef enum {
FIVE_BITS = 0x0,
SIX_BITS = 0x1,
SEVEN_BITS = 0x2,
EIGHT_BITS = 0x3
} UartBitsNum4Char;
typedef enum {
ONE_STOP_BIT = 0x1,
ONE_HALF_STOP_BIT = 0x2,
TWO_STOP_BIT = 0x3
} UartStopBitsNum;
typedef enum {
NONE_BITS = 0x2,
ODD_BITS = 1,
EVEN_BITS = 0
} UartParityMode;
typedef enum {
STICK_PARITY_DIS = 0,
STICK_PARITY_EN = 1
} UartExistParity;
typedef enum {
UART_None_Inverse = 0x0,
UART_Rxd_Inverse = UART_RXD_INV,
UART_CTS_Inverse = UART_CTS_INV,
UART_Txd_Inverse = UART_TXD_INV,
UART_RTS_Inverse = UART_RTS_INV,
} UART_LineLevelInverse;
typedef enum {
BIT_RATE_300 = 300,
BIT_RATE_600 = 600,
BIT_RATE_1200 = 1200,
BIT_RATE_2400 = 2400,
BIT_RATE_4800 = 4800,
BIT_RATE_9600 = 9600,
BIT_RATE_19200 = 19200,
BIT_RATE_38400 = 38400,
BIT_RATE_57600 = 57600,
BIT_RATE_74880 = 74880,
BIT_RATE_115200 = 115200,
BIT_RATE_230400 = 230400,
BIT_RATE_460800 = 460800,
BIT_RATE_921600 = 921600,
BIT_RATE_1843200 = 1843200,
BIT_RATE_3686400 = 3686400,
} UartBautRate;
typedef enum {
NONE_CTRL,
HARDWARE_CTRL,
XON_XOFF_CTRL
} UartFlowCtrl;
typedef enum {
USART_HardwareFlowControl_None = 0x0,
USART_HardwareFlowControl_RTS = 0x1,
USART_HardwareFlowControl_CTS = 0x2,
USART_HardwareFlowControl_CTS_RTS = 0x3
} UART_HwFlowCtrl;
typedef enum {
EMPTY,
UNDER_WRITE,
WRITE_OVER
} RcvMsgBuffState;
typedef struct {
uint32 RcvBuffSize;
uint8 *pRcvMsgBuff;
uint8 *pWritePos;
uint8 *pReadPos;
uint8 TrigLvl; //JLU: may need to pad
RcvMsgBuffState BuffState;
} RcvMsgBuff;
typedef struct {
uint32 TrxBuffSize;
uint8 *pTrxBuff;
} TrxMsgBuff;
typedef enum {
BAUD_RATE_DET,
WAIT_SYNC_FRM,
SRCH_MSG_HEAD,
RCV_MSG_BODY,
RCV_ESC_CHAR,
} RcvMsgState;
typedef struct {
UartBautRate baut_rate;
UartBitsNum4Char data_bits;
UartExistParity exist_parity;
UartParityMode parity;
UartStopBitsNum stop_bits;
UartFlowCtrl flow_ctrl;
RcvMsgBuff rcv_buff;
TrxMsgBuff trx_buff;
RcvMsgState rcv_state;
int received;
int buff_uart_no; //indicate which uart use tx/rx buffer
} UartDevice;
void uart_init(UartBautRate uart0_br, UartBautRate uart1_br);
void uart0_sendStr(const char *str);
#define UART_FIFO_LEN 128 //define the tx fifo length
#define UART_TX_EMPTY_THRESH_VAL 0x10
struct UartBuffer{
uint32 UartBuffSize;
uint8 *pUartBuff;
uint8 *pInPos;
uint8 *pOutPos;
STATUS BuffState;
uint16 Space; //remanent space of the buffer
uint8 TcpControl;
struct UartBuffer * nextBuff;
struct UartRxBuff{
uint32 UartRxBuffSize;
uint8 *pUartRxBuff;
uint8 *pWritePos;
uint8 *pReadPos;
STATUS RxBuffState;
uint32 Space; //remanent space of the buffer
typedef enum {
RUN = 0,
BLOCK = 1,
} TCPState;
//void ICACHE_FLASH_ATTR uart_test_rx();
STATUS uart_tx_one_char(uint8 uart, uint8 TxChar);
STATUS uart_tx_one_char_no_wait(uint8 uart, uint8 TxChar);
void uart1_sendStr_no_wait(const char *str);
struct UartBuffer* Uart_Buf_Init();
#if UART_BUFF_EN
LOCAL void Uart_Buf_Cpy(struct UartBuffer* pCur, char* pdata , uint16 data_len);
void uart_buf_free(struct UartBuffer* pBuff);
void tx_buff_enq(char* pdata, uint16 data_len );
LOCAL void tx_fifo_insert(struct UartBuffer* pTxBuff, uint8 data_len, uint8 uart_no);
void tx_start_uart_buffer(uint8 uart_no);
uint16 rx_buff_deq(char* pdata, uint16 data_len );
void Uart_rx_buff_enq();
#endif
void uart_rx_intr_enable(uint8 uart_no);
void uart_rx_intr_disable(uint8 uart_no);
#define FUNC_UART0_CTS 4
#define FUNC_U0CTS 4
#define FUNC_U1TXD_BK 2
#define UART_LINE_INV_MASK (0x3f<<19)
void UART_SetWordLength(uint8 uart_no, UartBitsNum4Char len);
void UART_SetStopBits(uint8 uart_no, UartStopBitsNum bit_num);
void UART_SetLineInverse(uint8 uart_no, UART_LineLevelInverse inverse_mask);
void UART_SetParity(uint8 uart_no, UartParityMode Parity_mode);
void UART_SetBaudrate(uint8 uart_no,uint32 baud_rate);
void UART_SetFlowCtrl(uint8 uart_no,UART_HwFlowCtrl flow_ctrl,uint8 rx_thresh);
void UART_WaitTxFifoEmpty(uint8 uart_no , uint32 time_out_us); //do not use if tx flow control enabled
void UART_ResetFifo(uint8 uart_no);
void UART_ClearIntrStatus(uint8 uart_no,uint32 clr_mask);
void UART_SetIntrEna(uint8 uart_no,uint32 ena_mask);
void UART_SetPrintPort(uint8 uart_no);
bool UART_CheckOutputFinished(uint8 uart_no, uint32 time_out_us);
#endif
My Makefile - Using "Make Flash"
CC = xtensa-lx106-elf-gcc
CFLAGS = -I. -DICACHE_FLASH -mlongcalls
LDLIBS = -nostdlib -Wl,--start-group -lmain -lpwm -lnet80211 -lwpa -llwip -lpp -lphy -lc -Wl,--end-group -lgcc
LDFLAGS = -Teagle.app.v6.ld
INCLUDES = -Iinclude -I../driver_lib/include
html:
esptool.py write_flash --flash_size 32m-c1 0x60000 index.html 0x65000 config.html
screen /dev/ttyUSB0 115200
main-0x00000.bin: main
echo a
echo $(LDFLAGS)
esptool.py elf2image $^
build-fotamain-0x81000.bin: LDFLAGS=-Teagle.app.v6.new.2048.ld
build-fotamain-0x81000.bin: main
esptool.py elf2image --version 2 main -o main-0x81000.bin
build-fotamain-0x01000.bin: LDFLAGS=-Teagle.app.v6.new.2048.ld
build-fotamain-0x01000.bin: main
esptool.py elf2image --version 2 main -o main-0x01000.bin
#fotamain-0x81000.bin: LDFLAGS=-Teagle.app.v6.new.1024.app2.ld
#fotamain-0x81000.bin: LDFLAGS=-Teagle.app.v6.new.2048.app2.ld
echo b
#echo $(LDFLAGS)
#esptool.py elf2image --version 2 main
#esptool.py write_flash --flash_size 32m-c1 0x81000 main-0x81000.bin
#esptool.py write_flash --flash_size 32m-c1 0x101000 main-0x101000.bin
#esptool.py write_flash --flash_size detect 0x101000 main-0x81000.bin
esptool.py write_flash --flash_size 32m-c1 0x101000 main-0x01000.bin
#fotamain-0x01000.bin: LDFLAGS=-Teagle.app.v6.new.1024.app1.ld
#For some reason the flag below is not applying
echo c
echo $(LDFLAGS)
esptool.py write_flash --flash_size 32m-c1 0 boot_v1.7.bin 0x1000 main-0x01000.bin 0x7e000 blank.bin 0xFE000 blank.bin 0x3FC000 ../library/esp_init_data_default_adc33.bin 0x60000 index.html 0x65000 config.html
main: main.o
main.o: main.c
dhonewire: dhonewire.o
dhonewire.o: dhonewire.c
fresh: clean main-0x00000.bin
echo d
echo $(LDFLAGS)
#kill $(ps aux | grep '[S]CREEN' | awk '{print $2}')
esptool.py erase_flash
esptool.py write_flash 0 main-0x00000.bin 0x10000 main-0x10000.bin 0x7e000 blank.bin 0x3fc000 ../library/esp_init_data_default_adc33.bin 0x3fe000 blank.bin 0x60000 index.html 0x65000 config.html
#screen /dev/ttyUSB0 74880
flash: LDFLAGS=-Teagle.app.v6.ld
flash: main-0x00000.bin
echo e
echo $(LDFLAGS)
esptool.py write_flash 0 main-0x00000.bin 0x10000 main-0x10000.bin 0x60000 index.html 0x65000 config.html
quick: main-0x00000.bin
echo f
echo $(LDFLAGS)
build: main-0x00000.bin
echo g
echo $(LDFLAGS)
ota: fotamain-0x01000.bin fotamain-0x81000.bin
#export -p
echo h
echo $(LDFLAGS)
screen:
clean:
echo i
rm -f main main.o main*.bin
#echo 'osboxes.org' | sudo -S chmod 777 /dev/ttyUSB0 #No longer needed, osboxes added to dialout group with usermod
cleanall:
echo j
rm -f main main.o main-0x00000.bin main-0x10000.bin main-0x81000.bin main-0x01000.bin
