NONOS - Anyone have any sample code of receiving UART data
AgentSmithers
- Contact:
Postby AgentSmithers » Wed Jan 24, 2018 3:26 pm
Also os_printf also appears to stop printing once I run uart_config. Any way to keep that functionality while using UART?
Thanks everyone!
Re: NONOS - Anyone have any sample code of receiving UART data
Postby Her Mary » Thu Jan 25, 2018 5:36 pm
// install uart1 putc callback
os_install_putc1((void *)uart1_write_char);//print output at UART1
AgentSmithers
- Contact:
Postby AgentSmithers » Fri Jan 26, 2018 12:25 am
Her Majesty wrote:You should note that the code below will change your os_printf to output from UART1. Maybe your application mistakenly called it.Code: Select all
Thanks!
I don't recall seeing this line but I'll take a look. Much appreciate. Thank you for your prompt response.
AgentSmithers
- Contact:
Postby AgentSmithers » Tue Jan 30, 2018 1:53 pm
I wrote this, However if I can write the 16 bytes before the WDT everything works great. As soon as I write one byte without the other 15 I get a WDT. Anyone know why? Like I need to clear the interrupt or something?
LOCAL void uart0_rx_intr_handler(void *para)
char RcvChar[4];
RcvMsgBuff *pRxBuff = (RcvMsgBuff *)para;
if (UART_RXFIFO_FULL_INT_ST != (READ_PERI_REG(UART_INT_ST(UART0)) & UART_RXFIFO_FULL_INT_ST)) {
return;
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_FULL_INT_CLR);
while (READ_PERI_REG(UART_STATUS(UART0)) & (UART_RXFIFO_CNT << UART_RXFIFO_CNT_S))
ETS_UART_INTR_DISABLE();
RcvChar[0] = READ_PERI_REG(UART_FIFO(UART0)) & 0xFF;
/* you can add your handle code below.*/
gpio_output_set(0, (1 << 2), 0, 0);
uart0_tx_buffer(RcvChar, 1);
// Clear pending FIFO interrupts
WRITE_PERI_REG(UART_INT_CLR(UART0), UART_RXFIFO_TOUT_INT_CLR | UART_RXFIFO_FULL_INT_ST);
ETS_UART_INTR_ENABLE();
AgentSmithers
- Contact:
Postby AgentSmithers » Tue Jan 30, 2018 2:13 pm
WRITE_PERI_REG(UART_CONF1(uart_no), ((0x01 & UART_RXFIFO_FULL_THRHD) << UART_RXFIFO_FULL_THRHD_S) | ((0x01 & UART_RX_FLOW_THRHD) << UART_RX_FLOW_THRHD_S) | UART_RX_FLOW_EN | (0x02 & UART_RX_TOUT_THRHD) << UART_RX_TOUT_THRHD_S | UART_RX_TOUT_EN);
Anyone have a link to the document for these flags? I don't see it in the Programming guide from Expressif.
Anyone know the line that adjust the parity on UART0?
EDIT:
I think i found the answer.
//WRITE_PERI_REG(UART_CONF0(uart_no), CALC_UARTMODE(UartDev.data_bits, UartDev.parity, UartDev.stop_bits));
WRITE_PERI_REG(UART_CONF0(uart_no), CALC_UARTMODE(UartDev.data_bits, NONE_BITS, UartDev.stop_bits));
So to see the current option set I assume I use GET_PERI_REG, as it stands using UartDev.data_bits set to the current value its set to with no changes correct?
Postby Her Mary » Wed Jan 31, 2018 2:03 pm
AgentSmithers
- Contact:
Postby AgentSmithers » Thu Feb 01, 2018 8:19 am
Her Majesty wrote:This document may help you https://www.espressif.com/sites/default/files/documentation/esp8266-technical_reference_en.pdf.
Ah that works!
Thanks. Give's me a good read.
