udp_join_multigrup failed!I validate that the station is connected and has a validate IP before issuing the mdns setup.
Postby DavidDPD » Thu Aug 06, 2015 10:59 am
udp_join_multigrup failed!Postby ESP_Faye » Fri Aug 07, 2015 7:25 pm
Postby DavidDPD » Mon Aug 10, 2015 1:30 pm
Espressif_Faye wrote:Hi,
Could you provide the captured packets for debugging ?
Could you provide your test code, we will have a try.
Postby ESP_Faye » Tue Aug 11, 2015 2:45 pm
static void CP_ICACHE_FLASH_ATTR
startup()
uint32 t;
uint32_t status;
char buffer[128] = {0};
struct ip_info ipconfig;
Postby DavidDPD » Fri Aug 21, 2015 2:08 pm
struct mdns_info *info = (struct mdns_info *)os_zalloc(sizeof(struct mdns_info));
info->ipAddr = ipconfig.ip.addr; //ESP8266 station IP
