I'm using printf() in my code for ESP8266 and found a weird phenomenon. In the setup printf(\n) generates me a CRLF but ones entered in the Loop() in one of the function calls it doesn't work any more. In this function call I have a
printf("Connected to: SSID: \t %-20s\n",WiFi.SSID(wifi.netindex).c_str() ); which works fine but ones i add a \n to the beginning and change it to printf("\nConnected to: SSID: \t %-20s\n",WiFi.SSID(wifi.netindex).c_str() ); it doesn't display anything at all
Does any one can give me and idea what going on.
An other strange behavior I saw with printf() in combination with Serial.print(). if you mix them than the screen output is not generated in the sequence the functions are used in the code. Print lines later in the code are earlier displayed. Are the printf() streams and Serial.print() streams independent processed by the RTOS of the ESP? and is this the cause of the problem?
I hope one of you can help me.
Thanks Oscar Goos
