Hello
I am using the sparkfun dev board called the "ESP8266 Thing".
It is provided with a 512Kbits AT25SF041-SSHD-B flash.
I was able to flash AT Firmware, make evaluations. Connect in WIFI, make UDP, TCP. That Was OK.
I changed the flash to a blank 1MB AT25DF081A-SSH-B to go further with your last SDK.
With It, I tried the "AT firmware which can upgrade by "AT+CIUPDATE"
The only way to avoid having a checksum problem on boot (the flash tool makes no check it seems)
was to make it run at 20Mhz with DOUT SPI mode.
But, still, now I get this message on reboot
tail 4
chksum 0x89
tail 4
chksum 0xe8
tail 8
chksum 0xc0
csum 0xc0
2nd boot version : 1.4(b1)
SPI Speed : 20MHz
SPI Mode : DOUT
jump to run user1 @ 1000
RTC dÐHfxP Ih-áêî
SDK ver: 1.2.0 compiled @ Jul 3 2015 19:36:17
phy ver: 356, pp ver: 8.7
nv version:ver0
[W]sec 7d error
[W]sec 7d error
[W]sec 7d error
etc...
and it then loops with these messages.
What does that mean ? Is this again a problem with the flash ?
If yes, isn't this flash reference supposed to work well with the ESP ?
thank you
Is this due to a problem with my flash
Re: Is this due to a problem with my flash
Postby ESP_Faye » Mon Aug 10, 2015 8:01 pm
1. AT firmware needs 1MBytes flash.
2."[W]sec 7d error" means the sector 7d of your flash can not be write. Please try to test it with another module or another flash.
