Fatal exception 29E:M 40
AgentSmithers
- Contact:
Postby AgentSmithers » Sat Feb 10, 2018 9:12 am
Anyone know the the heck this error is. I got this on the output. I am sending a Becon every 1 second and after maybe 100 or so it kicks this on the output
[MyCode debugoutput]
Dumping Data
80� 0 0 0 FF� FF� FF� FF� FF� FF� 1 2 3 4 5 6 1 2 3 4 5 6 C0� 6Cl 83� 51Q F7� 8F� F 0 0 0 64d 0 1 4 0 7 74t 65e 73s 74t 69i 6En 67g 1 82� 84� 8B� 96� 24$ 300 48H 6Cl 3 1 1 4CL 1A E B2� DD� BB�
sending: 0 - 58 size
sent: 0
[Error debugoutput]
12E:M 72
3Fatal exception 29E:M 40
Fatal exception 29
Dumping Data
sent: 0
[Error debugoutput]
12E:M 72
Fatal exception 29
AgentSmithers
- Contact:
Re: Fatal exception 29E:M 40
Postby AgentSmithers » Sat Feb 10, 2018 10:32 am
This may be my bad.. I was using ZeroAlloc and didnt use Free afterwords XD. i think its resolved.. Im still woundering though where the info is on the error list? That way I can look up future errors.
Postby XuHong » Thu Mar 01, 2018 2:43 pm
Have you solved the problem now? I had this problem on the MQTT Demo once every 1 second.
E:M 1560
E:M 1560
E:M 1560
E:M 16
E:M 16
E:M 48
E:M 16
E:M 32
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
TCP: Disconnected callback
MQTT: Disconnected-
AgentSmithers
- Contact:
Postby AgentSmithers » Fri Mar 02, 2018 12:44 am
XuHong wrote:Have you solved the problem now? I had this problem on the MQTT Demo once every 1 second.Code: Select all
E:M 1560
E:M 1560
E:M 1560
E:M 16
E:M 16
E:M 48
E:M 16
E:M 32
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
E:M 168
MQTT: Disconnected
I'm not sure if it's a problem other then running out of heap memory.
Create an empty project and use os_zalloc a few times without using free and see if that reproduces the issue. I think E:M is just stating that memory is low or out at this point, Not sure which yet.
