How to check if sntp_init() completed?
deadmetaphor
Postby deadmetaphor » Tue Aug 11, 2015 2:57 pm
I am trying to get the current time using the SNTP APIs in the SDK.
It works fine except that sometimes when I call
sntp_get_current_timestamp()
it returns the time equivalent to "1970.01.01 00:00:00" and logs an error
please start sntp first !
How to I test if sntp_init() has completed? Or, provide a callback perhaps?
Re: How to check if sntp_init() completed?
Postby ESP_Faye » Tue Aug 11, 2015 3:08 pm
Set a timer to check if current_stamp got a real timestamp, not 0 any more.
uint32 current_stamp;
current_stamp = sntp_get_current_timestamp();
We will update our example in documentation.
deadmetaphor
Postby deadmetaphor » Tue Aug 11, 2015 4:43 pm
Thanks!
derekh
Postby derekh » Thu Aug 13, 2015 1:52 pm
please consider adding a callback.
also when RTOS SDK will have SNTP support?
PaulTsai111
Postby PaulTsai111 » Fri Jun 03, 2016 6:47 pm
Hi Espressif :
I have encountered the same question , sntp_get_real_time got 1970 ..........
Can you show me where I can find espressif Documents ? about sntp_get_real_time usage ?
I hope to correct my code thanks you !!
Postby ESP_Faye » Mon Jun 06, 2016 10:14 am
Please refer to the documentation "ESP8266 Non-OS SDK API Guide" http://www.espressif.com/support/download/documents.
PaulTsai111
Postby PaulTsai111 » Tue Jun 07, 2016 11:38 am
Hi Espressif :
About the usage of testing the sntp I have changed to the api provided example way to do.
The results still shows sntp start first !
Does this sntp api should first connect to router ?
because connect to server right ?
Postby ESP_Faye » Wed Jun 08, 2016 2:05 pm
Yes. SNTP is getting time info from internet, it needs to connect to router first.
eriksl
Postby eriksl » Sun Jun 19, 2016 6:20 pm
The current (as of 1.5.2) implementation has a nasty quirk though. Time is only fetched ONCE. As the internal clock of the ESP8266 isn't quite "real time", your clock will be off by 1-60 minutes every 24h. The concept of NTP is that it's run periodically to care for clock drift. I had to workaround this by stopping and starting NTP every now and then.
