SDK 0.9.4: promiscuous mode capture packets
Postby reaper7 » Sun Dec 21, 2014 5:28 pm
original project:
https://github.com/ly0/esp8266-smartlink
mod version compiled both on 9.3 and 9.4:
http://www.esp8266.com/viewtopic.php?f=6&t=536#p5085
so, on SDK 9.3 we got necessary packets received in promiscuous mode for configure AP,
but on SDK 9.4 seems that some packets are ignored, as author wrote:
https://github.com/ly0/esp8266-smartlink/issues/1
maybe this cause are associated with this change:
"Update sniffer to support capture HT20/HT40 packet;"
Re: SDK 0.9.4: promiscuous mode capture packets
Postby ESP_Faye » Mon Dec 22, 2014 1:14 pm
We don't offer detail data info, but length of packet and some head info..
By the way, your smartlink seems hard to be commercial use,everyone can capture packets and get your ssid/password info ?
Postby reaper7 » Mon Dec 22, 2014 2:56 pm
P.S. - this is not "my smartlink" but for me is very useful (for non commercial usage of course),
if You change home ap password or installing modules in a new place, You can simply change ssid/pass on all esp devices in 5 seconds
without physical access to them.
Of course in this case ssid/pass are send in plain text, but each user can decide if it's worth to use.
You can also send encoded (in some basic way) text, there are several possibilities.
And Yes, every one can capture these packets and gets this info
(if they do not use software based on sniffer like in 9.4
Postby reaper7 » Wed Dec 24, 2014 1:07 am
if length of (SSID + TOKEN + PASS) <=22 everything is OK
but for length >22 chars, result PASSWORD contain chars from outside struct item sniffer_buf->buf (network_80211.h)
because buf item from this struct can accommodate only 48 elements
look at 2 examples (printable elements are shown as chars, rest as hex):
1. VIRTUAL SSID: abcdefgh<!-SL-!>ijklmnop
promiscuous_rx:
WIFI SMARTLINK RX LEN[64]
00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
@ 00 00 00 ff ff ff ff ff ff 0 a8 db a4 19 91
ff ff ff ff ff ff 05 00 18 a b c d e f
g h < ! - S L - ! > i j k l m n
01 00 ~ 00 f0 bf ff ? P 00 00 00 00 a3 d b6
-user/wifi.c-wifi_smartlink_promiscuous_rx WIFI SMARTLINK RECEIVED SSID:[abcdefgh] PASSWORD:[ijklmn ]2. VIRTUAL SSID: abcdefgh<!-SL-!>ijklmn
promiscuous_rx:
ff ff ff ff ff ff P & 00 16 a b c d e f
01 00 | 00 f0 bf ff ? P 00 00 00 00 a3 d b6
-user/wifi.c-wifi_smartlink_promiscuous_rx WIFI SMARTLINK RECEIVED SSID:[abcdefgh] PASSWORD:[ijklmn]in 1 example (WRONG RESULT) final PASSWORD: ijklmn after char "n" contains hex 0x01 but I can't show it on forum
it seems that some buffer is too small because in theory(IEEE) SSID may contains 32 chars
Postby jackon » Tue Jan 27, 2015 4:10 pm
reaper7 wrote:unfortunately half solved
1. VIRTUAL SSID: abcdefgh<!-SL-!>ijklmnopCode: Select all
promiscuous_rx:
2. VIRTUAL SSID: abcdefgh<!-SL-!>ijklmnCode: Select all
promiscuous_rx:
hi, reaper7
we expand buf from 48 to 112 in v0.9.5, so the method you used is workable.
pls have a try.
Postby reaper7 » Tue Jan 27, 2015 4:16 pm
for me this problem is solved, tnx!
Postby mlebel » Tue Feb 24, 2015 4:22 pm
Its all understood from the ESP2866 side, but the Android/iOS/PC side?
Is someone have an example of Android/iOS/PC app (source code) to send this type of packets?
Tn'x in advance,
Meir Lebel
