Installation problems
rlivio
Postby rlivio » Tue Mar 27, 2018 12:24 am
Hi
I am a new user of Espressif modules, I already write some software for ESP-01 with Arduino IDE, but I am looking for a more powerful development environment.
My PC run Windows 10 (just updated)
I installed Visual Studio C++ Enterprise 2017
I try to install ESP8266 Wizard 1.2.9 - OpenSource (1.0).exe but I get the following error.
Someone can help me?
Thank you
Livio
26/03/2018 19:19:27 - Microsoft VSIX Installer
26/03/2018 19:19:27 - -------------------------------------------
26/03/2018 19:19:27 - vsixinstaller.exe version:
26/03/2018 19:19:27 - 15.0.26228.9 built by: D15RTWSVC
26/03/2018 19:19:27 - Command line parameters:
26/03/2018 19:19:27 - C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\VSIXInstaller.exe,C:\Program Files (x86)\Relentless.rad\ESP8266Wizard\ESP8266Wizard.vsix
26/03/2018 19:19:27 - Initializing Install...
26/03/2018 19:19:27 - Extension Details...
26/03/2018 19:19:27 -    Identifier         : ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702
26/03/2018 19:19:27 -    Name               : ESP8266Wizard
26/03/2018 19:19:27 -    Author             : Mathieu St-Laurent - Rev OpenSource
26/03/2018 19:19:27 -    Version            : 1.2.9
26/03/2018 19:19:27 -    Description        : Create an ESP8266 C Project from SDK/Example or Blank Project
26/03/2018 19:19:27 -    Locale             : en-US
26/03/2018 19:19:27 -    MoreInfoURL        :
26/03/2018 19:19:27 -    InstalledByMSI     : False
26/03/2018 19:19:27 -    SupportedFrameworkVersionRange : [4.5,)
26/03/2018 19:19:27 -    SignatureState     : Unsigned
26/03/2018 19:19:27 -    Supported Products :
26/03/2018 19:19:27 -       Microsoft.VisualStudio.Community
26/03/2018 19:19:27 -          Version : [11.0,16.0)
26/03/2018 19:19:27 -    References         :
26/03/2018 19:19:27 -    Prerequisites      :
26/03/2018 19:19:27 -       -------------------------------------------------------
26/03/2018 19:19:27 -       Identifier   : Microsoft.VisualStudio.Component.VC.CoreIde
26/03/2018 19:19:27 -       Name         : Fonctionnalités de base C++ de Visual Studio
26/03/2018 19:19:27 - Signature Details...
26/03/2018 19:19:27 -    Extension is not signed.
26/03/2018 19:19:27 - Searching for applicable products...
26/03/2018 19:19:27 - Found installed product - Global Location
26/03/2018 19:19:27 - Found installed product - Visual Studio Enterprise 2017
26/03/2018 19:19:27 - PKGDEF Information: Looking for master PkgDef file, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\master.pkgdef
26/03/2018 19:19:27 - PKGDEF Information: Creating PkgDefCacheNonVolatile
26/03/2018 19:19:27 - PKGDEF Information: Double-checking master pkgdef file
26/03/2018 19:19:27 - PKGDEF Information: PkgDefManagement initialized
26/03/2018 19:19:27 - PKGDEF Information: RootFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\
26/03/2018 19:19:27 - PKGDEF Information: ShellFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\
26/03/2018 19:19:27 - PKGDEF Information: PkgDefSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\devenv.admin.pkgdef
26/03/2018 19:19:27 - PKGDEF Information: ImageManifestSearchPath, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions;C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions;C:\Users\livio\AppData\Local\Microsoft\VisualStudio\15.0_b7b3e97f\Extensions
26/03/2018 19:19:27 - PKGDEF Information: ApplicationExtensionsFolder, Path: C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\Extensions
26/03/2018 19:19:27 - PKGDEF Information: "ZeroImpact" = dword:0, "MergeRegistry" = dword:3
26/03/2018 19:19:27 - PKGDEF Information: Could not find ConfigurationChanged timestamp., PKGDEF: 80070002
26/03/2018 19:19:27 - PKGDEF Information: User extensions enabled by setting, Path: HKEY_CURRENT_USER\Software\Microsoft\VisualStudio\15.0_b7b3e97f\ExtensionManager\EnableAdminExtensions
26/03/2018 19:19:27 - PKGDEF Information: PkgDefCache flags, PKGDEF: 7001
26/03/2018 19:19:27 - PKGDEF Information: PkgDefManagement startup complete
26/03/2018 19:19:28 - The extension with ID 'ESP8266Wizard.Mathieu St-Laurent.2369a963-05dc-4156-8143-c93633763702' is not installed to Visual Studio Enterprise 2017.
26/03/2018 19:19:40 - The following target products have been selected...
26/03/2018 19:19:40 -    Visual Studio Enterprise 2017
26/03/2018 19:19:40 - Beginning to install extension to Visual Studio Enterprise 2017...
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.2,6.3)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.81 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.3,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.D3DCompiler.Msu.Win7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.FullRedist.NonThreshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.NET.4.6.FullRedist.NonThreshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.Debugger.DbgHelp.Win8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.Debugger.Remote.DbgHelp.Win8 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Windows.UniversalCRT.Msu.7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.DiagnosticsHub.KB2882822.Win7 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package WebSocket4NetV2 is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.2)'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.Threshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[10.0.10240]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.Threshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[10.0.10240]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.6.1.FullRedist.NonThreshold is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.NET.4.6.1.FullRedist.NonThreshold.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,6.4)'.
26/03/2018 19:19:42 - Package Microsoft.Windows.81SDK.Store.DirectX.Msi is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Windows.81SDK.Desktop.DirectX.Msi is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1,6.3]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.FullRedist is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.14393]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.FullRedist.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.14393]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.1.FullRedist is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.15063]'.
26/03/2018 19:19:42 - Package Microsoft.Net.4.7.1.FullRedist.Resources is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '[6.1.1,10.0.15063]'.
26/03/2018 19:19:42 - Package Microsoft.VisualStudio.OfficeDeveloperTools.WindowsIdentityFoundation.Msu is not applicable. Skipping it due to the following reason(s): The current OS Version '10.0.16299.0' is not in the supported version range '(,6.2)'.
26/03/2018 19:19:43 - Package 'Microsoft.VisualStudio.SLNX.VSIX,version=15.0.426.61103' failed to install. System.IO.IOException: The file 'C:\Program Files (x86)\Microsoft Visual Studio\2017\Enterprise\Common7\IDE\CommonExtensions\Microsoft\OpenFolder\catalog.json' already exists.
   in Microsoft.VisualStudio.Setup.Installer.VsixInstaller.InstallCore(String localPath, String installDir, InstallablePackage pkg)
   in Microsoft.VisualStudio.Setup.Installer.InstallerBase.InstallHelper(InstallData installData)
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectServices,version=15.6.10.12453' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectServices,version=15.6.10.12453' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.ServiceHub,version=1.2.60.51671' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.ServiceHub,version=1.2.60.51671' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TeamExplorer,version=15.0.27509' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TeamExplorer,version=15.0.27509' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.TeamFoundation.OfficeIntegration.Resources,version=15.129.27509.11,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.TeamFoundation.OfficeIntegration,version=15.129.27509.11,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.TeamExplorer,version=15.129.27509.11' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TextMateGrammars,version=15.0.80116.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TextMateGrammars,version=15.0.80116.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.Build,version=15.6.82.30579,chip=neutral,language=neutral' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build,version=15.6.82.30579,chip=neutral,language=neutral' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build.FileTracker.Msi,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.Build.Dependencies,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.Build.Dependencies,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.DiaSymReader,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.DiaSymReader,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphProvider.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphProvider.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphProvider,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphProvider,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphModel.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphModel.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.GraphModel,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.GraphModel,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.PerformanceProvider,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PerformanceProvider,version=15.0.26504.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Progression,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VirtualTree.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VirtualTree.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VirtualTree,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VirtualTree,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine.Resources,version=15.0.27005.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.Core.VCProjectEngine,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Ide.WinXPlus,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.MSBuild.ARM,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VS.VC.MSBuild.X64.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Items.Pro.Resources,version=15.0.26208.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping download of package 'Microsoft.VisualStudio.VC.Items.Pro,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.DevCmd.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.DevCmd.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.DevCmd,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.DevCmd,version=15.6.27421.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Core.DotNet,version=15.0.27019.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Core.DotNet,version=15.0.27019.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Core.WinSdk,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Core.WinSdk,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VsDevCmd.Ext.NetFxSdk,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.VsDevCmd,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'PortableFacades,version=1.6.0.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.Utils.Resources,version=14.10.26128.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.Utils,version=14.10.26128.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualCpp.Tools.Common.UtilsPrereq,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualCpp.Tools.Common.UtilsPrereq,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.CoreEditor,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Component.CoreEditor,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Workload.CoreEditor,version=15.0.27205.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Editors,version=15.6.0.6270707' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.MinShell.Interop.Msi,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Devenv.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Msi,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Msi.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.MSHtml,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.WebSiteProject.DTE.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.WebSiteProject.DTE.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.WebSiteProject.DTE,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.WebSiteProject.DTE,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Net.Eula.Resources,version=15.0.27205.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Net.Eula.Resources,version=15.0.27205.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.CollectorCab,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.CollectorCab,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.x64,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.x64,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Community.x86,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Community.x86,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectSystem,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ProjectSystem.Full,version=15.6.201.1098' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.CommunityCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.ShDocVw,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Enterprise.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Enterprise,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Enterprise.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.EnterpriseCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional.Msi,version=15.0.26621.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Professional.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Professional,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.ProfessionalCore,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ClientDiagnostics,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ClientDiagnostics,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness.Targeted,version=15.6.27406.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.AppResponsiveness,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.AppResponsiveness,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.PackageGroup.ClientDiagnostics,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Resources,version=15.6.27428.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.DiagnosticsHub.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.DiagnosticsHub.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.IntelliTrace.DiagnosticsHub,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.IntelliTrace.DiagnosticsHub,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost.Resources,version=15.6.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost.Targeted,version=15.6.27413.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost.Targeted,version=15.6.27413.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.ScriptedHost,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.ScriptedHost,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.MSVCDis,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.MSVCDis,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger,version=15.6.27428.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger,version=15.6.27428.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote.Resources,version=15.6.27428.1,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Remote,version=15.6.27428.1,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Managed.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Managed.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.ExpressionEvaluator,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.ExpressionEvaluator.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.ExpressionEvaluator.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next,version=2.7.0.6271505' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next.Resources,version=15.6.27309.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.CodeAnalysis.VisualStudio.Setup.Next.Resources,version=15.6.27309.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Managed,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Managed,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.CollectionAgents,version=15.6.27309.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.CollectionAgents,version=15.6.27309.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Parallel.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Parallel.Resources,version=15.6.27406.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Parallel,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Parallel,version=15.6.27406.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Common.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Common.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Common,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Common,version=15.6.27309.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Debugger.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Debugger.Resources,version=15.6.27323.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Debugger,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Debugger,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.VSCodeDebuggerHost,version=15.6.20118.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Debugger.Core,version=15.0.27005.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TestTools.TeamFoundationClient.Resources,version=15.6.27428.2005,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TestTools.TeamFoundationClient.Resources,version=15.6.27428.2005,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.TestTools.TeamFoundationClient,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.TestTools.TeamFoundationClient,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.CodeSense,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.CodeSense,version=15.6.27428.2005' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Core,version=15.0.26906.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.MDD.Resources,version=15.0.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.MDD.Resources,version=15.0.27413.0,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.MDD,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.MDD,version=15.6.27413.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.JavaScript.LanguageService.Resources,version=15.0.26621.2,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.JavaScript.LanguageService,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.JavaScript.LanguageService,version=15.6.27323.2' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x86,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Resources,version=15.0.27205.0,chip=x64,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x86' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script,version=15.0.27205.0,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.Debugger.Script.Msi,version=15.0.27005.2,chip=x64' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.PackageGroup.Debugger.Script,version=15.0.26208.0' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Base.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Base.Resources,version=15.6.27421.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise.Resources,version=15.0.27128.1,language=it-IT' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Progression.Enterprise,version=15.0.27128.1' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.Ide.Base,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping cache of package 'Microsoft.VisualStudio.VC.Ide.Base,version=15.6.27428.2011' since the package or a parent package had a vital failure.
26/03/2018 19:19:43 - Skipping Install of 'Microsoft.VisualStudio.VC.MSBuild.Base.Resources,version=15.6.27413.0,language=it-IT' since ...
NidaAmber
Re: Installation problems
Postby NidaAmber » Wed May 09, 2018 6:20 pm
The best software after Arduino is raspberry pie. Do use it and if a case of any error. Contact me. I will help you for sure.
