ESP8266 Receive overflow
hhc
Postby hhc » Thu Aug 13, 2015 5:47 pm
ESP8266 sometimes give Rx OVF when we send data to it at a baud rate of 576000. It does not seem to appear with 115200. Does CTS (MTD0) work in ESP8266? We pull down that pin using 4.7k resistor. Will it affect anything?
Regards,
Hew
Version
AT version:0.30.0.0(Jul  3 2015 19:35:49)
SDK version:1.2.0
compile time:Jul 20 2015 18:15:27
ESP8266 set to handle flow control
AT+UART_CUR=576000,8,1,0,3
We send new data only after receiving SEND OK.
AT+CIPSTART=0,"TCP","xxx.xxx.xx.xxx",8888
0,CONNECT
AT+CIPBUFSTATUS=0
0,21,20,20,2920,8
AT+CIPSENDBUF=0,1400
21,20
Recv 1400 bytes
0,21,SEND OK
22,21
Recv 1400 bytes
0,22,SEND OK
23,22
Recv 1400 bytes
0,23,SEND OK
AT+CIPSENDBUF=0,875
24,23
(no more SEND OK here since ESP8266 Rx OVF)
debug port output
tcp client connect
pespconn 0x3fff4270
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
RX OVF!
flyfish
Re: ESP8266 Receive overflow
Postby flyfish » Thu Aug 20, 2015 5:28 pm
Rx OVF is because the baud rate of 576000 is to high(576000 bit/s is about 57kB/s). Hard flow control should be considered.
