ESP8266ex && sdhc 32GB / SDHC instead SPI flash
User avatar
rudi
Postby rudi » Thu Aug 13, 2015 6:26 pm
hi
is there a pcb layout recommendation for manufacturer who wants make an ESP8266 SDHC Module ,
or adapt an SDHC holder interface
example without a spi flash ic, only use sdhc card -
example with combine a spi flash ic - with 'hardware' boot choice by solder pad.
are there general recommendation for manufacturer from espressif using sdhc ?
txs
best wishes
rudi ;-)
my found for test sdhc & esp8266ex module was
adapter: http://www.ebay.de/itm/171168414356
just in time, there is a german manufacturer who build new module for me -
i will use this in a new ESP8266 Module with SDHC ( 32 GB )
holder: http://www.ebay.de/itm/171738462758
@AI Thinker Team
Are you planning to bring out a module with SDHC?
example SDHC in (H) SPI Mode...
Credit for (H) SPI goes
costaud
metalphreak
example
Found HSPI Overlap Mode by 'costaud'
viewtopic.php?f=15&t=56
Found (H)SPI driver by 'metalphreak'
Have a look to the MCP23S17 Portextender ( 2x8GPIO )
viewtopic.php?f=15&t=422
The FAT32 credit goes to elm chan ;-)
http://elm-chan.org/fsw/ff/00index_e.html
and the rest all was not difficult to bring together
Example code for LUNA
ESP8266 Module with a SDHC 32GB you will found here:
http://www.mikrocontroller.net/topic/370665#4222927
File: http://www.mikrocontroller.net/attachme ... _fat32.zip
SDHC 32 GB in (H)SPI example:
MOSI.. GPIO 13
MISO.. GPIO 12
CLK... GPIO 14
CS.... GPIO 15 !
ESP8266 Modul && MCP23S17 Portexpansion (LCD&&GPIO), && HSPI SDHC 32GB(16GB) (Simple Adapter) , in Background, CAN IC ( this is an extra for IoT 4.0 )
問候飛出去的朋友遍全球魯迪
User avatar
rudi
Re: ESP8266ex && sdhc 32GB / SDHC instead SPI flash
Postby rudi » Sat Aug 15, 2015 11:15 pm
update
add in makefile: -std=gnu90
# compiler flags using during compilation of source files
CFLAGS      = -Os -g -O2 -std=gnu90 -Wpointer-arith -Wundef -Werror -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals  -D__ets__ -DICACHE_FLASH
Info ( ESP8266 IDE luna)
Changelog:
v2.0.7 (09.07.2015):
* Updated compiler xtensa-lx106-gcc and xtensa-lx106-g++ up to version
5.1 (big thanks jcmvbkbc);
ATTENTION! For correct build of your firmware, you must add the option
-std=gnu90 in directive CFLAGS in Makefile
example makefile is here:
thread post: http://www.mikrocontroller.net/topic/370665#4223524
link to the file: http://www.mikrocontroller.net/attachme ... 0/Makefile
src:
# Root Level Makefile
# (c) by CHERTS <sleuthhound@gmail.com>
# check it out for kettenrad
# rudi ;-)
BUILD_BASE   = build
FW_BASE      = firmware
# Base directory for the compiler
XTENSA_TOOLS_ROOT ?= c:/Espressif/xtensa-lx106-elf/bin
# base directory of the ESP8266 SDK package, absolute
SDK_BASE   ?= c:/Espressif/ESP8266_SDK
# esptool path and port
SDK_TOOLS   ?= c:/Espressif/utils
ESPTOOL      ?= $(SDK_TOOLS)/esptool.exe
# hi kettenrad - aendere deinen com port
ESPPORT      ?= COM4
ESPBAUD      ?= 115200 #921600
# BOOT = none
# BOOT = old - boot_v1.1
# BOOT = new - boot_v1.3+
BOOT?=none
# APP = 0 - eagle.flash.bin + eagle.irom0text.bin
# APP = 1 - user1.bin
# APP = 2 - user2.bin
APP?=0
# SPI_SPEED = 20MHz, 26.7MHz, 40MHz, 80MHz
SPI_SPEED?=40
# SPI_MODE: QIO, QOUT, DIO, DOUT
SPI_MODE?=QIO
# SPI_SIZE: 256KB, 512KB, 1024KB, 2048KB, 4096KB
SPI_SIZE?=512
ifeq ($(BOOT), new)
    boot = new
else
    ifeq ($(BOOT), old)
        boot = old
    else
        boot = none
    endif
endif
ifeq ($(APP), 1)
    app = 1
else
    ifeq ($(APP), 2)
        app = 2
    else
        app = 0
    endif
endif
ifeq ($(SPI_SPEED), 26.7)
    freqdiv = 1
    flashimageoptions = -ff 26m
else
    ifeq ($(SPI_SPEED), 20)
        freqdiv = 2
        flashimageoptions = -ff 20m
    else
        ifeq ($(SPI_SPEED), 80)
            freqdiv = 15
            flashimageoptions = -ff 80m
        else
            freqdiv = 0
            flashimageoptions = -ff 40m
        endif
    endif
endif
ifeq ($(SPI_MODE), QOUT)
    mode = 1
    flashimageoptions += -fm qout
else
    ifeq ($(SPI_MODE), DIO)
        mode = 2
        flashimageoptions += -fm dio
    else
        ifeq ($(SPI_MODE), DOUT)
            mode = 3
            flashimageoptions += -fm dout
        else
            mode = 0
            flashimageoptions += -fm qio
        endif
    endif
endif
# flash larger than 1024KB only use 1024KB to storage user1.bin and user2.bin
ifeq ($(SPI_SIZE), 256)
    size = 1
    flash = 256
    flashimageoptions += -fs 2m
else
    ifeq ($(SPI_SIZE), 1024)
        size = 2
        flash = 1024
        flashimageoptions += -fs 8m
    else
        ifeq ($(SPI_SIZE), 2048)
            size = 3
            flash = 1024
            flashimageoptions += -fs 16m
        else
            ifeq ($(SPI_SIZE), 4096)
                size = 4
                flash = 1024
                flashimageoptions += -fs 32m
            else
                size = 0
                flash = 512
                flashimageoptions += -fs 4m
            endif
        endif
    endif
endif
ifeq ($(flash), 512)
  ifeq ($(app), 1)
    addr = 0x01000
  else
    ifeq ($(app), 2)
      addr = 0x41000
    endif
  endif
else
  ifeq ($(flash), 1024)
    ifeq ($(app), 1)
      addr = 0x01000
    else
      ifeq ($(app), 2)
        addr = 0x81000
      endif
    endif
  endif
endif
# name for the target project
TARGET      = app
# which modules (subdirectories) of the project to include in compiling
MODULES      = driver user
EXTRA_INCDIR    = include $(SDK_BASE)/../include
# libraries used in this project, mainly provided by the SDK
LIBS      = c gcc hal phy pp net80211 lwip wpa main #json upgrade at smartconfig
# linker flags used to generate the main object file
LDFLAGS      = -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static
# linker script used for the above linkier step
LD_SCRIPT   = eagle.app.v6.ld
ifneq ($(boot), none)
ifneq ($(app),0)
   LD_SCRIPT = eagle.app.v6.$(boot).$(flash).app$(app).ld
   BIN_NAME = user$(app).$(flash).$(boot)
endif
else
    app = 0
endif
# various paths from the SDK used in this project
SDK_LIBDIR   = lib
SDK_LDDIR   = ld
SDK_INCDIR   = include include/json
# select which tools to use as compiler, librarian and linker
CC      := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
AR      := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-ar
LD      := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-gcc
OBJCOPY := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-objcopy
OBJDUMP := $(XTENSA_TOOLS_ROOT)/xtensa-lx106-elf-objdump
# no user configurable options below here
SRC_DIR      := $(MODULES)
BUILD_DIR   := $(addprefix $(BUILD_BASE)/,$(MODULES))
SDK_LIBDIR   := $(addprefix $(SDK_BASE)/,$(SDK_LIBDIR))
SDK_INCDIR   := $(addprefix -I$(SDK_BASE)/,$(SDK_INCDIR))
SRC      := $(foreach sdir,$(SRC_DIR),$(wildcard $(sdir)/*.c))
OBJ      := $(patsubst %.c,$(BUILD_BASE)/%.o,$(SRC))
LIBS      := $(addprefix -l,$(LIBS))
APP_AR      := $(addprefix $(BUILD_BASE)/,$(TARGET)_app.a)
TARGET_OUT   := $(addprefix $(BUILD_BASE)/,$(TARGET).out)
LD_SCRIPT   := $(addprefix -T$(SDK_BASE)/$(SDK_LDDIR)/,$(LD_SCRIPT))
INCDIR   := $(addprefix -I,$(SRC_DIR))
EXTRA_INCDIR   := $(addprefix -I,$(EXTRA_INCDIR))
MODULE_INCDIR   := $(addsuffix /include,$(INCDIR))
V ?= $(VERBOSE)
ifeq ("$(V)","1")
Q :=
vecho := @true
else
Q := @
vecho := @echo
endif
vpath %.c $(SRC_DIR)
define compile-objects
$1/%.o: %.c
   $(vecho) "CC $$<"
   $(Q) $(CC) $(INCDIR) $(MODULE_INCDIR) $(EXTRA_INCDIR) $(SDK_INCDIR) $(CFLAGS)  -c $$< -o $$@
endef
.PHONY: all checkdirs clean flash flashinit flashonefile rebuild
all: checkdirs $(TARGET_OUT)
$(TARGET_OUT): $(APP_AR)
   $(vecho) "LD $@"
   $(Q) $(LD) -L$(SDK_LIBDIR) $(LD_SCRIPT) $(LDFLAGS) -Wl,--start-group $(LIBS) $(APP_AR) -Wl,--end-group -o $@
   $(vecho) "------------------------------------------------------------------------------"
   $(vecho) "Section info:"
   $(Q) $(OBJDUMP) -h -j .data -j .rodata -j .bss -j .text -j .irom0.text $@
   $(Q) $(SDK_TOOLS)/memanalyzer.exe $(OBJDUMP).exe $@
   $(vecho) "Run objcopy, please wait..."
   $(Q) $(OBJCOPY) --only-section .text -O binary $@ eagle.app.v6.text.bin
   $(Q) $(OBJCOPY) --only-section .data -O binary $@ eagle.app.v6.data.bin
   $(Q) $(OBJCOPY) --only-section .rodata -O binary $@ eagle.app.v6.rodata.bin
   $(Q) $(OBJCOPY) --only-section .irom0.text -O binary $@ eagle.app.v6.irom0text.bin
   $(vecho) "objcopy done"
   $(vecho) "Run gen_appbin.exe"
ifeq ($(app), 0)
   $(Q) $(SDK_TOOLS)/gen_appbin.exe $@ 0 $(mode) $(freqdiv) $(size)
   $(Q) mv eagle.app.flash.bin $(FW_BASE)/eagle.flash.bin
   $(Q) mv eagle.app.v6.irom0text.bin $(FW_BASE)/eagle.irom0text.bin
   $(Q) rm eagle.app.v6.*
   $(vecho) "No boot needed."
   $(vecho) "Generate eagle.flash.bin and eagle.irom0text.bin successully in folder $(FW_BASE)."
   $(vecho) "eagle.flash.bin-------->0x00000"
   $(vecho) "eagle.irom0text.bin---->0x40000"
else
    ifeq ($(boot), new)
      $(Q) $(SDK_TOOLS)/gen_appbin.exe $@ 2 $(mode) $(freqdiv) $(size)
      $(vecho) "Support boot_v1.3 and +"
    else
      $(Q) $(SDK_TOOLS)/gen_appbin.exe $@ 1 $(mode) $(freqdiv) $(size)
      $(vecho) "Support boot_v1.1 and +"
    endif
   $(Q) mv eagle.app.flash.bin $(FW_BASE)/upgrade/$(BIN_NAME).bin
   $(vecho) "Generate $(BIN_NAME).bin successully in folder $(FW_BASE)/upgrade."
   $(vecho) "boot_v1.x.bin------->0x00000"
   $(vecho) "$(BIN_NAME).bin--->$(addr)"
endif
   $(vecho) "Done"
$(APP_AR): $(OBJ)
   $(vecho) "AR $@"
   $(Q) $(AR) cru $@ $^
checkdirs: $(BUILD_DIR) $(FW_BASE)
$(BUILD_DIR):
   $(Q) mkdir -p $@
$(FW_BASE):
   $(Q) mkdir -p $@
   $(Q) mkdir -p $@/upgrade
flashonefile: all
   $(OBJCOPY) --only-section .text -O binary $(TARGET_OUT) eagle.app.v6.text.bin
   $(OBJCOPY) --only-section .data -O binary $(TARGET_OUT) eagle.app.v6.data.bin
   $(OBJCOPY) --only-section .rodata -O binary $(TARGET_OUT) eagle.app.v6.rodata.bin
   $(OBJCOPY) --only-section .irom0.text -O binary $(TARGET_OUT) eagle.app.v6.irom0text.bin
   $(SDK_TOOLS)/gen_appbin_old.exe $(TARGET_OUT) v6
   $(SDK_TOOLS)/gen_flashbin.exe eagle.app.v6.flash.bin eagle.app.v6.irom0text.bin 0x40000
   rm -f eagle.app.v6.data.bin
   rm -f eagle.app.v6.flash.bin
   rm -f eagle.app.v6.irom0text.bin
   rm -f eagle.app.v6.rodata.bin
   rm -f eagle.app.v6.text.bin
   rm -f eagle.app.sym
   $(vecho) "Generate eagle.app.flash.bin successully in folder $(FW_BASE)."
   $(vecho) "eagle.app.flash.bin-------->0x00000"
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) 0x00000 $(FW_BASE)/eagle.app.flash.bin
flashboot: all flashinit
ifeq ($(boot), new)
   $(vecho) "Flash boot_v1.3 and +"
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) 0x00000 $(SDK_BASE)/bin/boot_v1.3\(b3\).bin
endif
ifeq ($(boot), old)
   $(vecho) "Flash boot_v1.1 and +"
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) 0x00000 $(SDK_BASE)/bin/boot_v1.1.bin
endif
ifeq ($(boot), none)
endif
flash: all
ifeq ($(app), 0)
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) 0x00000 $(FW_BASE)/eagle.flash.bin 0x40000 $(FW_BASE)/eagle.irom0text.bin
else
else
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) $(addr) $(FW_BASE)/upgrade/$(BIN_NAME).bin
endif
endif
flashinit:
   $(vecho) "Flash init data:"
   $(vecho) "Clear old settings (EEP area):"
   $(vecho) "clear_eep.bin-------->0x79000"
   $(vecho) "Default config (Clear SDK settings):"
   $(vecho) "blank.bin-------->0x7E000"
   $(vecho) "esp_init_data_default.bin-------->0x7C000"
   $(ESPTOOL) -p $(ESPPORT) -b $(ESPBAUD) write_flash $(flashimageoptions) 0x79000 $(SDK_BASE)/bin/clear_eep.bin 0x7c000 $(SDK_BASE)/bin/esp_init_data_default.bin 0x7e000 $(SDK_BASE)/bin/blank.bin
rebuild: clean all
clean:
   $(Q) rm -f $(APP_AR)
   $(Q) rm -f $(TARGET_OUT)
   $(Q) rm -rf $(BUILD_DIR)
   $(Q) rm -rf $(BUILD_BASE)
   $(Q) rm -rf $(FW_BASE)
$(foreach bdir,$(BUILD_DIR),$(eval $(call compile-objects,$(bdir))))
問候飛出去的朋友遍全球魯迪
