Greetings to All,
I am trying to set up GPIO-based interrupt using the RTOS SDK (see code below).
It seems I need to use the gpio_pin_intr_state_set() function but it is missing from the SDK libraries. Any help would be greatly appreciated!
Best,
Emmanuel
void main_int_handler()
printf("main_int_callback!\n");
int i;
uint32 gpio_status = GPIO_REG_READ(GPIO_STATUS_ADDRESS);
uint32 gpio_mask = _xt_read_ints();
printf("Generic interrupt gpio_mask= 0x%08x, status = 0x%08x\n",gpio_mask,gpio_status);
for (i=0 ; i<16 ; i++) {
if ((0x1<<i) & gpio_status) {
printf("Mask set %d\n",i);
void registerInterrupt(int pin, GPIO_INT_TYPE mode)
portENTER_CRITICAL();
// disable open drain
GPIO_REG_WRITE(GPIO_PIN_ADDR(GPIO_ID_PIN(pin)),
GPIO_REG_READ(GPIO_PIN_ADDR(GPIO_ID_PIN(pin))) & (~ GPIO_PIN_PAD_DRIVER_SET(GPIO_PAD_DRIVER_ENABLE)));
//clear interrupt status
GPIO_REG_WRITE(GPIO_STATUS_W1TC_ADDRESS, BIT(pin));
// set the mode
_xt_isr_unmask(1<<ETS_GPIO_INUM);
//gpio_pin_intr_state_set(GPIO_ID_PIN(pin), mode); // does not link if this line is enabled...
portENABLE_INTERRUPTS();
portEXIT_CRITICAL();
in user_init():
_xt_isr_attach(ETS_GPIO_INUM, (_xt_isr)main_int_handler, NULL);
registerInterrupt(15, GPIO_PIN_INTR_ANYEDGE); // setting INT on GPIO15
GPIO interrupt using RTOS SDK: how to?
