ESP01 - AT 0.40 - Can't save baud rate change
Postby hexor » Thu Aug 20, 2015 8:14 pm
Due to my problem with AT 0.21 (viewtopic.php?f=16&t=976) I want to test with the last update (but I'm still want to understand where is the bug in v0.21).
I have flashed an esp01 with the last AT firmware, but If I want to change the baud rate to 19200 with "AT+UART_DEF=19200,8,1,0,0"
The baud is changed, but If i cut off the power, at the next boot the baud rate is 115200 and not 19200.
Do you know why I can't save this parameter ?
Thanks a lot for your hard work on the esp's World !!!
Re: ESP01 - AT 0.40 - Can't save baud rate change
Postby ESP_Faye » Fri Aug 21, 2015 10:53 am
What is the size of your flash ?
If your flash size is 512KB, AT_v0.40 can only work well without OTA:
eagle.flash.bin 0x00000
eagle.irom0text.bin 0x40000
blank.bin 0x3e000 & 0x7e000
If your problem is still unsolved, please provide the capture picture of your flash download tool while downloading.
Postby ESP_Faye » Mon Aug 24, 2015 3:46 pm
Please use the Espressif Flash Download Tool and select the "SpiAutoSet" to download firmware.
Then the ESP Flash Download Tool will set the configuration automatically according to your Flash while downloading.
Postby hexor » Mon Aug 24, 2015 4:21 pm
After the flashing, all is working, I can change the baud rate, but if I reboot, the baud returning to 115200.
AT
AT+GMR
SDK version:1.3.0
compile time:Aug 8 2015 17:35:24
------------ [CHANGING BAUD RATE ON MY SOFTWARE TO 19200 ------------
AT
AT+GMR
SDK version:1.3.0
OKThis is the capture during the flash:
And the path are:
Thanks for your help
Postby ESP_Faye » Tue Aug 25, 2015 11:22 am
I tried it on ESP01, but I still can not duplicate your problem...
How did you know that the baud rate change back to 115200 ?
Could you try it with another PC UART tool, for example, “secureCRT” ?
Postby hexor » Tue Aug 25, 2015 4:58 pm
I know the baud rate is 115200 after reboot because it's the only baud rate that is good to communicate with the ESP01.
19200 dosen't work and return weird character.
I have already try several UART software and several ESP01.... --> same result
Postby ESP_Faye » Wed Aug 26, 2015 10:03 am
So sorry that I still can not duplicate your problem..
Here is my test AT bin files, please have a try.
And you could also provide your test bin, I will test it.
// Change baud rate of PC UART tool to 19200
at
AT+RST
卆鰾a跆黙c1cV匍5BRb/VT毈鬜ル凝汐B
ready
AT
- Attachments
- at_bin_sdk130.zip
- (182.54 KiB) Downloaded 920 times
Postby hexor » Wed Aug 26, 2015 3:58 pm
AT
AT+GMR
SDK version:1.3.0
//Change soft baud to 19200
AT
AT+RST
úFX
Xû
XJÒBÂXX~
BbKBà9rb*Ê5ãCÊ^T_Ç^þýùý
//Trying to send "AT"
ùù
//Change soft baud to 115200
AT
AT
OKThis is my bin files:
- sdk130.zip
- (180.84 KiB) Downloaded 819 times
I don't understand where is the problem
