SPI_FLASH_INSTRUCTION_CODE ( 0x4B ) for get the UID 64 Bit MAC of Winbond
User avatar
rudi
Postby rudi » Thu Aug 20, 2015 11:15 pm
hi espressif
have we an official api for comunicate with the SPI_FLASH?
i mean not the read, write function to a SPI_FLASH to store or read bytes.
right, we have an api command to read the manufacturer id
spi_flash_get_id()
but i mean, is there an official api to send instruction code to the SPI FLASH
example :
to read the SPI_FLASH MAC ID - i mean the uinique id ( 64 Bit )
read Winbond - instruction code byte is : 0x4B
there is a unique 64bit MAC/ID at address 0X4B on the flash chip.
this could be very useful in uniquely identifying flash ic in a large manufacturer
and history database for firmware / updates.
the UID number can be used in conjunction with user software methods
to help prevent copying or cloning of a system.
linked to a pdf ( example the W25Q64CV )
because file is too big for upload.
https://www.winbond.com/resource-files/w25q64cv_revh_052214[2].pdf
please have a look to side 55
point : 7.2.3.4 Read Unique ID Number (4BH)
please support this as an api instruction.
please support to can send other instruction code too.
example: 7.2.39 Read Security Registers ( 48h )
there are more interesst instruction code
i have write/request this more as one time i know -
please support this in an api command official
thank you!
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
User avatar
rudi
Re: SPI_FLASH_INSTRUCTION_CODE ( 0x4B ) for get the UID 64 Bit MAC of Winbond
Postby rudi » Sun Sep 20, 2015 10:55 am
push #
問候飛出去的朋友遍全球魯迪
User avatar
rudi
Postby rudi » Tue Sep 22, 2015 2:53 am
Solved and DONE
got my new flash ic's just in time- so i have a short try with this 32Mbit,
and runs like clockwork in my code - i solved this now- and can go next step to make fw better proteced.
if you can support this in your api too - would be fine step -
"Thanks for your interest in this...
問候飛出去的朋友遍全球魯迪
lihwarlee
Postby lihwarlee » Sat Jan 16, 2016 9:15 am
Do you have any sample code about reading Unique ID of W25Q32 ?
Pls send the SAMPLE CODE to me, E-mail: 64569224@qq.com
Thank you.
I have use your SPI driver to debug this, but it is NOT success.
void ReadFlashID(BYTE *pManuId, BYTE *pDevId)
BYTE tmp;
spi_master_init(0);
spi_mast_byte_write(0, 0x90);
// spi_byte_write_espslave(0, 0x90);
os_delay_us(200);
// SPI_REG8(PUB_SPICMD_WR_BYTE, 0x90);
spi_mast_byte_write(0, 0x00);
// spi_byte_write_espslave(0, 0x00);
os_delay_us(200);
// SPI_REG8(PUB_SPICMD_WR_BYTE, 0x00);
os_delay_us(200);
os_delay_us(200);
// spi_mast_byte_write(0, 0x00);
os_delay_us(200);
// SPI_REG8(PUB_SPICMD_RD_BYTE, 0x00); //read the last byte
spi_byte_read_espslave(0, &tmp);
*pManuId = tmp;
os_delay_us(200);
// SPI_REG8(PUB_SPICMD_RD_LASTBYTE, 0x00); //read the last byte
*pDevId = tmp;
User avatar
rudi
Postby rudi » Mon Jan 25, 2016 4:21 am
Thank you.
BYTE tmp;
spi_master_init(0);
os_delay_us(200);
os_delay_us(200);
os_delay_us(200);
os_delay_us(200);
os_delay_us(200);
*pManuId = tmp;
os_delay_us(200);
*pDevId = tmp;
hi
how you have "connect" the spi_master_init(0); by pins to your flash chip ?
do you connect a second spi flash or will you read from boot flash as connected is Quad?
be sure you have read the datasheet, there are Standard, Dual and Quad Instructions.
try to read the modes are can used:
http://www.winbond-usa.com/resource-fil ... 202015.pdf
examples
side 61, 62, 63
and then you know how you must handle UID:
side 64
and jedec ( manufacturer )
side 65
btw, jedec is supported in last Flash Tool, the src is in the folder too.
viewtopic.php?f=5&t=433
 def get_flash_id(self):
   try:
       self.flash_begin(0,0)
       self.write_reg(self.ESP_DATA_ADDR, 0 , 0 , 0 )
       time.sleep(0.01)
       self.write_reg(self.ESP_CMD_ADDR , self.ESP_CMD_RDID , self.ESP_CMD_RDID , 0 )
       time.sleep(0.01)
       flash_id = self.read_reg(self.ESP_DATA_ADDR)
       print "get flash id : 0x%08x"%flash_id
       self.flash_manufacturer_id = flash_id&0xff
       self.flash_device_id = ((flash_id>>16)&0xff | (flash_id &( 0xff<<8)))
       print " manufacturer_id: 0x%x\r\n"%self.flash_manufacturer_id
       print " device_id: 0x%x\r\n"%self.flash_device_id
       return True
   except:
       print "get flash id error"
       return False
   #self.mp.textCtrl_BinPath3.AppendText("\r\nFLASH:\r\n")
   #self.mp.textCtrl_BinPath3.AppendText("manufacturer_id: %xh\r\n"%manufacturer_id)
   #self.mp.textCtrl_BinPath3.AppendText("device_id:%xh\r\n"%device_id)
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
User avatar
rudi
Postby rudi » Mon Jan 25, 2016 9:15 am
hint
UID = only in SPI MODE
JEDEC = SPI & QPI Mode
hope now is clear:
and why we have no SDK_API for the Quad connected Flash
if you want read the UID from Quad connected Flash
you must overlap a user SPI Mode. ( use bitbanged mode, its the easiest way for his )
search.php?keywords=overlap+spi
hope this helps
best wishes
rudi ;-)
問候飛出去的朋友遍全球魯迪
adhopraz
Postby adhopraz » Tue Nov 27, 2018 4:45 pm
Tks Rudy, It's work for me :D
