AT+CIPSEND= ....SEND FAIL
cesar.guevara
Postby cesar.guevara » Mon Feb 08, 2016 4:42 am
I'm configuring my ESP8266 as a TCP Server, everything works great except when I try to send data to a client.
As a comment I am using as power source an Arduino UNO, but I'm conifguring the module via AT commands through a USB-UART Connected to my computer.
This is the error I got:
1,CONNECT
CIPSEND=1,10
Recv 10 bytes
1,CONNECT FAIL
SEND FAIL
I'm using the lastest firmware for 4mb Flash, v1.4, sometimes the module let me send 3 frames, some others no one, I imagine maybe the power source can generate this disconnection,
Could you confirm if this is the reason?
Re: AT+CIPSEND= ....SEND FAIL
Postby ESP_Faye » Tue Mar 01, 2016 10:51 am
When ESP8266 runs as TCP server, it will disconnect to the TCP clients who did not communicate with it until time out.
Command "AT+CIPSTO" can set the timeout. You can try to set the timeout to be longer.
kurtisulrich
Postby kurtisulrich » Fri Feb 17, 2017 12:26 am
i have a esp8266-01 with
AT+GMRAT version:0.40.0.0(Aug 8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
works fine
but i bought another esp8266-01 and updated the firmware to the latest and i get send failed error
i have tried every thing
AT+CIPSTO=0
AT+CIPSTO=10
AT+CIPSTO=7200
NOTHING WORKS
NEED HELP
kurtisulrich
Postby kurtisulrich » Fri Feb 17, 2017 12:32 am
CIPSEND=0,1400
Recv 1400 bytes
0,CONNECT FAIL
SEND FAIL
I have an esp8266-01 that has old firmware on it
SDK version:1.3.0
and this works great
i bought another esp8266-01 and updated to the latest firmware and i keep getting this messasge
0,CONNECT
CIPSEND=0,1400
Recv 1400 bytes
0,CONNECT FAIL
SEND FAIL
i have tried everything
AT+CIPSTO=0
AT+CIPSTO=10
AT+CIPSTO=7200
nothing works
need help
Postby 朝花夕拾 » Fri Sep 15, 2017 9:32 am
is there anyone could help me to resolve this problems?
this is received from esp8266's uart;
busy s...
0,CONNECT FAIL
SEND FAIL
AT+CIPSEND=0,20
link is not valid
ERROR
my test case is esp8266 connect to an AP,and got ip address,esp8266 create a TCP server;
the next, my cellphone connect to the same AP,and create a TCP client;
my cellphone(TCP client) sends 20bytes data to esp8266(TCP server) , its frequence is 1s a once;
after several hours , esp8266's responses like this ;
is this a esp8266's firmware problem?
but what's the reason?
thanks very much;
pulfli
Postby pulfli » Mon Dec 02, 2019 7:10 pm
I have the same problem with several ESP8266s.
I also have problems to connect to these ESP8266 from a Computer.
Version:
AT version:1.6.2.0(Apr 13 2018 11:10:59)
SDK version:2.2.1(6ab97e9)
compile time:Jun 7 2018 19:34:29
Bin version(Wroom 02):1.6.2
Output:
Recv 14 bytes
0,CONNECT FAIL
SEND FAIL
I also have some ESP8266s with exactly the same configuration, which work absolutely perfect!
I hope you can help me with this problem.
Greetings
Sharon Nisha
Postby Sharon Nisha » Mon Apr 13, 2020 11:10 pm
It worked well for me after setting
AT+CWMODE=1
Regards
