wifi_station_set_wpa2_enterprise_auth(true);
wifi_station_set_reconnect_policy(false);
wifi_station_set_enterprise_username((u8*)EAP_USER, os_strlen(EAP_USER));
wifi_station_set_enterprise_password((u8*)EAP_PASSWORD, os_strlen(EAP_PASSWORD));
wifi_station_connect();
heap 46040 wifi status 1
state: 2 -> 0 (0)
scandone
state: 0 -> 2 (b0)
state: 2 -> 3 (0)
state: 3 -> 5 (10)
add 0
aid 1
cnt
Method private structure allocated failure
Full program here.
https://github.com/dfries/source-code-e ... ser_main.c
user_config.h
#define SSID "Your SSID"
#define SSID_PASSWORD "Your Password Here"
#define EAP_USER "eap_username"
#define EAP_PASSWORD "eap_password"
user_main.c
#include "ets_sys.h"
#include "osapi.h"
#include "gpio.h"
#include "os_type.h"
#include "user_config.h"
#include "user_interface.h"
#include <wpa2_enterprise.h>
#define user_procTaskPrio 0
#define user_procTaskQueueLen 1
os_event_t user_procTaskQueue[user_procTaskQueueLen];
static void loop(os_event_t *events);
static void ICACHE_FLASH_ATTR
print_heap(os_event_t *events)
int status = wifi_station_get_connect_status();
os_printf("heap %u wifi status %u\n", system_get_free_heap_size(), status);
if(status == STATION_IDLE)
os_printf("idle, try connecting\n");
static int connect_count;
if(status == STATION_CONNECTING)
++connect_count;
if(connect_count == 4)
os_printf("still in connecting, disconnect and try again\n");
wifi_station_disconnect();
connect_count = 0;
//Init function
user_init()
char ssid[32] = SSID;
char password[64] = SSID_PASSWORD;
// default appears to be a non-standard 74880 baud
//Set station mode
//Set ap settings
// skip station config, expect the station is already setup in flash
#if 0
#endif
os_printf("heap %u line %u\n", system_get_free_heap_size(), __LINE__);
static os_timer_t heap_timer;
os_timer_disarm(&heap_timer);
os_timer_setfn(&heap_timer, &print_heap, NULL);
os_timer_arm(&heap_timer, 3000, 1);
