ESP8266 2MB + OTA
JulienInnovel
ESP8266 2MB + OTA
Postby JulienInnovel » Tue Feb 06, 2018 1:01 am
I'm using an ESP-WROOM-02 (ESP8266 + 2MB of SPI flash).
I'm trying to do OTA tests with mode 512KB + 512KB, to have 1024KB of user data (I have some data do store into flash and I don't want to erase them with OTA, user data stored at @ 0x100000).
I build my first firmware (V1) with linker script "eagle.app.v6.new.2048.ld", option "16m" (not "16m-c1").
I flash my ESP with ESP FLASH TOOL with this parameters :
SPI speed : 40MHz
SPI mode : QIO
Flash size : 16m
and files :
boot_v1.7.bin @0x00000
user1.bin @0x01000
blank.bin @0x1fb000
esp_init_data_default.bin @0x1fc000
blank.bin @0x1fe000
My ESP start correctly (USART prompt ) :
load 0x40100000, len 2592, room 16
tail 0
chksum 0xf3
load 0x3ffe8000, len 764, room 8
tail 4
chksum 0x92
load 0x3ffe82fc, len 676, room 4
tail 0
chksum 0x22
csum 0x22
2nd boot version : 1.7(5d6f877)
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user1 @ 1000
rf cal sector: 507
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
w_flash
SDK ver: 2.1.0(116b762) compiled @ May 5 2017 16:08:55
phy ver: 1134_0, pp ver: 10.2
Now, I want to upgrade my ESP by OTA to firmware version 2 (same as version 1 but only version number has changed) :
It's working perfectly, reboot and prompt this :
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
jump to run user2 @ 81000
rf cal sector: 507
freq trace enable 0
rf[112] : 00
rf[113] : 00
rf[114] : 01
Now, I want to upgrade to the firmware version 3 (same has others, but only version number changed to 3) :
GET /user1.bin HTTP/1.0
Connection: close
actual bin : UPGRADE_FW_BIN2
system_upgrade_start
upgrade_connect 45736
[OTA]Upgrading...
upgrade_connect_cb
pusrdata = HTTP/1.0 200 OK
Content-Length: 234820
sumlength = 234820
sec_block 58
..........................................................upgrade_get_sum_disconcb 45544
And nothing else.... Reboot it self and only print this :
tail 0
chksum 0xf3
tail 4
chksum 0x92
tail 0
chksum 0x22
csum 0x22
SPI Speed : 40MHz
SPI Mode : QIO
And my ESP is broken...
I must erase all, and flash it again.
It seems like the firmware 2 is erasing itself or something else..
Any one have any idea ?
AgentSmithers
- Contact:
Re: ESP8266 2MB + OTA
Postby AgentSmithers » Wed Feb 07, 2018 2:36 am
JulienInnovel
Postby JulienInnovel » Wed Feb 07, 2018 8:56 pm
You can add me, my skype is j.reynaud_7
JulienInnovel
Postby JulienInnovel » Thu Feb 08, 2018 5:28 pm
I have the bootloader for 16Mbit (512 + 512) and I can use OTA to flash firmware and automatically jump to user 1 or user 2, and have a user data flash at the end (from @0x100000 to @0x1FC000).
But, why I must use the 1MB linker ?
The linker for 2MB can't do 512+512 ?
Postby Her Mary » Mon Feb 12, 2018 5:27 pm
And you should note that the system parameter area is always the last 4 or 5 sectors of your flash (16Mbit), you should not save any user data there.
JulienInnovel
Postby JulienInnovel » Mon Feb 12, 2018 6:55 pm
Yes, I select the 16Mbit flash when I download the firmware.
My user data selection is from @0x100000 to @0x1FC000 (like defined in the IOT SDK USER MANUAL).
AgentSmithers
- Contact:
Postby AgentSmithers » Sun Feb 18, 2018 2:03 pm
JulienInnovel wrote:Hi, thanks.
I added you but havent been accepted yet.
AgentSmithers
- Contact:
Postby AgentSmithers » Thu Dec 09, 2021 5:09 pm
#ifndef __httpPostFota__
#define __httpPostFota__
#include <upgrade.h>
//#define UPGRADE_DEBUG
#ifdef UPGRADE_DEBUG
#define UPGRADE_DBG os_printf
#else
#define UPGRADE_DBG
#endif
#define FOTAHTMLSIZE 8192
typedef void (*FOTAWebRecvFunctionCallback)(void *arg, char *pusrdata, unsigned short length);
FOTAWebRecvFunctionCallback FOTAWebRecvCallBack;
unsigned char * FOTAFormatedHTMLPageWithHttpHeader;
LOCAL struct espconn FOTAWebServerSocket;
static char *FOTAmsg_espconn_state[] =
"NONE",
"WAIT",
"LISTEN",
"CONNECT",
"WRITE",
"READ",
"CLOSE"
char * FOTAHttpHeader = "HTTP/1.1 200 OK\r\nContent-Length: %d\r\nConnection: close\r\n\r\n";
LOCAL void ICACHE_FLASH_ATTR FOTAHttpSendWithHeader(struct espconn * WifiScanConfigConnection, unsigned char * LFormatedHTMLPage) //This may be able to be merged
FOTAFormatedHTMLPageWithHttpHeader = (unsigned char*)os_zalloc(FOTAHTMLSIZE);
if (FOTAFormatedHTMLPageWithHttpHeader == 0x0)
os_printf("[%s][%s][%d] - Unable to Alloc memory, exiting\r\n", __FILE__ ,__func__, __LINE__);
return;
os_printf("Attaching header and sending\r\n");
os_memset(FOTAFormatedHTMLPageWithHttpHeader, 0, FOTAHTMLSIZE);
os_sprintf(FOTAFormatedHTMLPageWithHttpHeader, FOTAHttpHeader, os_strlen(LFormatedHTMLPage));
os_strcat(FOTAFormatedHTMLPageWithHttpHeader, LFormatedHTMLPage);
espconn_send(WifiScanConfigConnection, (uint8*)FOTAFormatedHTMLPageWithHttpHeader, os_strlen(FOTAFormatedHTMLPageWithHttpHeader));
os_printf("HTTP Response sent bytes: %d\r\n", os_strlen(LFormatedHTMLPage));
os_free(FOTAFormatedHTMLPageWithHttpHeader);
LOCAL os_timer_t Firmware_Timer;
static ETSTimer http2spi_flash_reboot_timer;
LOCAL char* ICACHE_FLASH_ATTR http2spi_checkheader(void *buf, int which)
os_printf("[%s]\r\n", __func__);
uint8_t *cd = (uint8_t *)buf;
uint32_t *buf32 = buf;
os_printf("OTA hdr %p: %08lX %08lX %08lX %08lX\n", buf,
(long unsigned int)buf32[0],
(long unsigned int)buf32[1],
(long unsigned int)buf32[2],
(long unsigned int)buf32[3]);
if (cd[0] != 0xEA) return "IROM magic missing";
if (cd[1] != 4 || cd[2] > 3 || (cd[3]>>4) > 6) return "bad flash header";
//if (cd[3] < 3 && cd[3] != which) return "Wrong partition binary";
if (((uint16_t *)buf)[3] != 0x4010) return "Invalid entry addr";
if (((uint32_t *)buf)[2] != 0) return "Invalid start offset";
return NULL;
long gstaticContentLength = 0; //This keeps the Content length in mem for the life of the transactions
long gContentLength = 0; //This is a countdown of Binary Data left to transmit to the client, this includes the Mime header data! Anything after first CRLFCRLF basiclly
uint16 RemotePortsOpenedInDownload = 0; //Only One port at a time can upload a firmware
bool HeaderRead = false;
int dataparts = 0; //This track the file transfer progress in packets
char FOTAdatabuffer[4] = {0}; //Rolling Ring Buffer
uint32 FOTAdatabufferindex = 0;
uint32_t FOTAburnto = 0x0;
uint32_t gOffset = 0x0;
LOCAL void ICACHE_FLASH_ATTR FOTAWebServerConn_recv_callback(void *arg, char *pusrdata, unsigned short length)
bool unloadafter = false;
struct espconn * FOTApespconn = (struct espconn *) arg;
//os_printf("[%s] Client recv'ed from port: ", __func__);
uint16_printf(FOTApespconn->proto.tcp->remote_port);
os_printf(" - ");
uint16_printf(FOTApespconn->proto.tcp->local_port);
//os_printf(FOTApespconn->proto.tcp->client_port);
//os_printf(FOTApespconn->tcp.client_port); //How to identify which socket is triggering this WebServerCallback. What if multiple clients are connected?
os_printf("\r\n");
char* getpost = strstr(pusrdata, "POST /upload");
if (getpost != NULL)
if (RemotePortsOpenedInDownload == FOTApespconn->proto.tcp->remote_port)
//os_printf("Incoming file data gcontentlength = %u lCurrentIncomming: %u\r\n", gContentLength, length);
if (dataparts <= 6)
dataparts++;
//os_printf(pusrdata);
//hex_printf(pusrdata, length);
//os_printf("\r\n-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-\r\n");
char * Ptr = pusrdata;
if (HeaderRead == false) //Move past the header
os_printf("Header removed\r\n");
while (!strstarts(Ptr, "\r\n\r\n"))
Ptr++; //Increment Ptr
//lengthleft--;
while (*Ptr == '\n' || *Ptr == '\r')
//lengthleft--;
os_printf("%u - %u!\r\n", Ptr, pusrdata);
os_printf("Before %u!\r\n", length);
length -= Ptr-pusrdata;
gContentLength -= length;
os_printf("After removing headers %u! Updating gContentLength(%u)\r\n", length, gContentLength);
HeaderRead = true;
//os_printf("---");
//os_printf(Ptr);
//os_printf("gcontentlength(%d) - thispacketLength(%d) = %d remainding, DbufferIndex(%u)\r\n", gContentLength, length, (gContentLength - length), FOTAdatabufferindex);
unsigned short i,ii = 0;
for (i=0; i<length; i++)
if (i == 0)
for (ii=0; ii<10; ii++)
os_printf("%x ", *(Ptr + ii));
os_printf("\r\n");
if (gContentLength < 3000)
if (*(Ptr + i) == '-' && *(Ptr + i + 1) == '-' && *(Ptr + i + 2) == '-' && *(Ptr + i + 3) == '-' && *(Ptr + i + 4) == '-' && *(Ptr + i + 5) == '-')
//os_printf("Found Hyphens EOF -\r\n");
char * ResponseToSend = "<!DOCTYPE html><html><head><meta http-equiv=\"refresh\" content=\"3;URL='/'\"></head><body>File Uploaded</body></html>";
FOTAHttpSendWithHeader(FOTApespconn, ResponseToSend);
system_update_cpu_freq(80);
return;
//os_printf("i=%d", i);
system_soft_wdt_feed();
FOTAdatabuffer[FOTAdatabufferindex%4] = *(Ptr + i);
FOTAdatabufferindex++;
if (FOTAdatabufferindex%4 == 0)
if (spi_flash_write(gOffset, (uint32 *)&FOTAdatabuffer, 4) == SPI_FLASH_RESULT_OK)
if (gOffset % 0x10000 == 0)
os_printf("%u of packet %u - %x %x %x %x Writen to offset 0x%x bin=0x%x bytesleft=%u!\r\n", i, length, FOTAdatabuffer[0], FOTAdatabuffer[1], FOTAdatabuffer[2], FOTAdatabuffer[3], gOffset, gOffset-FOTAburnto, gContentLength-FOTAdatabufferindex);
if (gstaticContentLength - FOTAdatabufferindex < 0x30)
//os_printf("%u of packet %u - %x %x %x %x Writen to offset 0x%x bin=0x%x bytesleft=%u!\r\n", i, length, databuffer[0], databuffer[1], databuffer[2], databuffer[3], gOffset, gOffset-FOTAburnto, gContentLength-FOTAdatabufferindex);
if (FOTAdatabufferindex > gContentLength - 0x10 || FOTAdatabufferindex < 0x10 )// || i < 0x100 //This does for every packet
//os_printf("%u of packet %u - %x %x %x %x Writen to offset 0x%x bin=0x%x bytesleft=%u\r\n", i, length, databuffer[0], databuffer[1], databuffer[2], databuffer[3], gOffset, gOffset-FOTAburnto, gContentLength-FOTAdatabufferindex);
gOffset += 4;
else
os_printf("failed writing length:%d\r\n", length);
if (FOTAdatabufferindex > 60)
//return;
//os_printf("Packet Processed ContentLength(%u) of packet FOTAdatabufferindex(%u) Difference(%u)\r\n", gstaticContentLength, FOTAdatabufferindex, (gstaticContentLength - FOTAdatabufferindex));
if (gContentLength == 0)
//espconn_disconnect(&FOTAWebServerSocket); //Webservers don't close sockets, clients do
char * ResponseToSend = "<!DOCTYPE html><html><body>File Uploaded</body></html>";
if (strstr(pusrdata, "POST /upload") != NULL)
system_update_cpu_freq(160);
dataparts = 1;
RemotePortsOpenedInDownload = FOTApespconn->proto.tcp->remote_port;
int index = 0;
while (!strstarts(Ptr, "Content-Length: "))
Ptr++; //Increment Potr
while (*Ptr != ' ')
Ptr++; //Increment to Content String
char ContentLength[8] = {0};
index = 0;
while (*Ptr != '\r' && *Ptr != '\n')
ContentLength[index] = *Ptr;
index++;
os_printf(ContentLength);
gContentLength = atoi(ContentLength);
gstaticContentLength = gContentLength;
Ptr = pusrdata; //Reset PTR
while (!strstarts(Ptr, "Content-Type: multipart/form-data; boundary="))
while (*Ptr != '=')
char Boundary[64] = {0};
index = 0;
Boundary[index] = *Ptr;
index++;
//os_printf("%u\r\n", Ptr);
Boundary[index] = 0; //This may not be needed by the way I declared boundary with = {0}
os_printf(Boundary);
os_printf("\r\n");
Ptr += 4;
os_printf("HEAD Content Length of file: %d\r\n", gContentLength); //Start erasing the flash at a given address
if(system_upgrade_userbin_check() == 0)
FOTAburnto = 0x101000;
else
FOTAburnto = 0x1000;
gOffset = FOTAburnto;
uint32_t poffset = 0x0;
for (poffset=0x0; gContentLength-poffset>0; poffset++)
if ((FOTAburnto+poffset) % SPI_FLASH_SEC_SIZE == 0)
//os_printf("Erasing 0x%x\r\n", FOTAburnto+poffset);
spi_flash_erase_sector((FOTAburnto+poffset)/SPI_FLASH_SEC_SIZE); //Doing it here may not be fast enough.
HeaderRead = false; //SetHeader back to false to prep for incoming header to skip
os_printf("%u\r\n", pusrdata);
os_printf("%u\r\n", (Ptr-pusrdata));
//os_printf("%u\r\n", (pusrdata-Ptr)); //This loops around the interger value giving a result back in the 4millons
os_printf("Length: %u\r\n", length);
os_printf("Logic:%u\r\n", length-(Ptr-pusrdata));
//os_printf("%u\r\n", (&Ptr-&pusrdata)); //We don't really care about the addresses
//os_printf("%u\r\n", (&pusrdata-&Ptr));
if(length-(Ptr-pusrdata) > 0) //It's possible data can be fragmented from the first packet
unsigned short packetlen = length-(Ptr-pusrdata);
os_printf("Calling first packet remainding len:%u of %u\r\n", packetlen, length);
FOTAWebServerConn_recv_callback(arg, Ptr, packetlen);//This function normally dosn't get called by chrome being predictable during development, This may change later sadly if IE frags the packets differently
else
//This is not normally called.
if (strstr(pusrdata, "GET /favicon.ico HTTP/1.1") != NULL) //Skip FavIcon request
return;
if (strstr(pusrdata, "GET / HTTP/1.1") != NULL) //Display Config request
char * ResponseToSend = NULL;
os_printf("[%s]s\r\n", __func__);
if (system_get_userbin_addr() == 0x0)
os_printf("OTA Firmware is not detected, please load the OTA firmware\r\n");
ResponseToSend = "<!DOCTYPE html><html><body>OTA Firmware is not detected, please load the OTA firmware</body></html>";
else
ResponseToSend = "<!DOCTYPE html><html><body><form action=\"upload\" method=\"post\" enctype=\"multipart/form-data\">Select image to upload to address 0x101000:<input type=\"file\" name=\"fileToUpload\" id=\"fileToUpload\"><input type=\"submit\" value=\"Upload Image\" name=\"submit\"></form></body></html>";
else
ResponseToSend = "<!DOCTYPE html><html><body><form action=\"upload\" method=\"post\" enctype=\"multipart/form-data\">Select image to upload to address 0x1000:<input type=\"file\" name=\"fileToUpload\" id=\"fileToUpload\"><input type=\"submit\" value=\"Upload Image\" name=\"submit\"></form></body></html>";
os_printf("[%s]s1\r\n", __func__);
//espconn_send(FOTApespconn, ResponseToSend, os_strlen(ResponseToSend));
os_printf("[%s]s2\r\n", __func__);
LOCAL void ICACHE_FLASH_ATTR FOTAWebServerConn_connect_callback(void *arg)
os_printf("[%s] Client Connected from port: ", __func__);
os_printf(" - ");
os_printf("\r\n");
return;
remot_info *premot = NULL;
uint8 reter = espconn_get_connection_info(FOTApespconn,&premot,0);
if (reter == ESPCONN_OK)
if(FOTApespconn->link_cnt)
os_printf("EspConn %u TCP connections:\r\n", FOTApespconn->link_cnt);
int i = 0;
while(i < FOTApespconn->link_cnt)
os_printf("%d) " IPSTR ":%u %s\r\n", i, IP2STR(premot[i].remote_ip), premot[i].remote_port, FOTAmsg_espconn_state[premot[i].state] );
i++;
else
os_printf("EspConn getting TCP connections failed: %d\r\n", reter);
void ICACHE_FLASH_ATTR FOTAWebServerConn_disconnect_callback(void *arg)
os_printf("[%s] Client Disconnected from port: ", __func__);
os_printf(" - ");
os_printf("\r\n");
os_printf("Last Status: gcontentlength(%d), DbufferIndex(%u)\r\n", gContentLength, FOTAdatabufferindex);
uint32 Http2SPI_buf[8];
spi_flash_read(FOTAburnto, Http2SPI_buf, sizeof(Http2SPI_buf));
uint8 id = system_upgrade_userbin_check();
char *err = http2spi_checkheader(Http2SPI_buf, 1-id);
if (err != NULL) {
os_printf("OTA Not a bootable bin, %s\n HTTP to SPI completed.\r\n", err);
return -1;
os_printf("Reboot needed, rebooting...");
// Schedule a reboot
os_timer_disarm(&http2spi_flash_reboot_timer);
os_timer_setfn(&http2spi_flash_reboot_timer, (os_timer_func_t *)system_upgrade_reboot, NULL);
os_timer_arm(&http2spi_flash_reboot_timer, 2000, 1);
void ICACHE_FLASH_ATTR FOTAWebServerConn_sent_callback(void *arg)
os_printf("[%s] Data Sent\r\n", __func__);
void ICACHE_FLASH_ATTR init_FOTAwebserver(uint16 port, void * LFOTAWebRecvCallBack(void *arg, char *pusrdata, unsigned short length)) //LFOTAWebRecvCallBack may need to point to the next pointer of the function and not the parent recv function
//FOTAFormatedHTMLPageWithHttpHeader = (unsigned char*)os_zalloc(FOTAHTMLSIZE); //Never alloc on init. only when the far is used then free it asap!
if (LFOTAWebRecvCallBack != NULL)
os_printf("Setting Callback for WebServer\r\n");
FOTAWebRecvCallBack = LFOTAWebRecvCallBack;
FOTAWebServerSocket.type = ESPCONN_TCP;
FOTAWebServerSocket.state = ESPCONN_NONE;
FOTAWebServerSocket.proto.tcp = (esp_tcp *)os_zalloc(sizeof(esp_tcp));
if (FOTAWebServerSocket.proto.tcp == 0x0)
return;
FOTAWebServerSocket.proto.tcp->local_port = port; // ESP8266 tcp port
espconn_accept(&FOTAWebServerSocket); // create tcp
espconn_regist_connectcb(&FOTAWebServerSocket, FOTAWebServerConn_connect_callback);
espconn_regist_recvcb(&FOTAWebServerSocket, FOTAWebServerConn_recv_callback); // register a tcp packet receiving callback
espconn_regist_sentcb(&FOTAWebServerSocket, FOTAWebServerConn_sent_callback);
espconn_regist_disconcb(&FOTAWebServerSocket, FOTAWebServerConn_disconnect_callback);
#endif
You can run the server with something like this
init_FOTAwebserver(9999, NULL);
Once ran, browse to the ESP's ip on that port and you should get prompted with a button to upload your OTA file. From what I recall I tested and valided this code a few years back.
Postby FrenkR » Wed Oct 05, 2022 9:30 am
I run into the same problem I believe. ESP-WROOM02 (16M, 512+512 OTA), bootloader 1.7, SDK 3.0.5, partition table:
#define SYSTEM_PARTITION_OTA_SIZE 0x6A000
#define SYSTEM_PARTITION_OTA_2_ADDR 0x81000
#define SYSTEM_PARTITION_RF_CAL_ADDR 0x1fb000
#define SYSTEM_PARTITION_PHY_DATA_ADDR 0x1fc000
#define SYSTEM_PARTITION_SYSTEM_PARAMETER_ADDR 0x1fd000
#define SYSTEM_PARTITION_CUSTOMER_PRIV_PARAM_ADDR 0x7c000
I found following. Upgrade from user1 -> user2 works. When chip is running user2 code and I remove code "user1.bin" (OTA partition 1), system stops working and following error is displayed:
Fatal exception (0):
epc1=0x40213e48, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
0x40213e48 via disassembler points to following:
40213e48 <init_bss_data>:
40213e48: fffe61 l32r a6, 40213e40 <print_system_param_sectors+0x18>
40213e4b: fffe41 l32r a4, 40213e44 <print_system_param_sectors+0x1c>
40213e4e: 050c movi.n a5, 0
40213e50: 07b467 bgeu a4, a6, 40213e5b <init_bss_data+0x13>
40213e53: 004452 s8i a5, a4, 0
40213e56: 441b addi.n a4, a4, 1
40213e58: f79467 bne a4, a6, 40213e53 <init_bss_data+0xb>
40213e5b: f00d ret.n
40213e5d: 00 .byte 00
40213e5e: 00 .byte 00
40213e5f: 00 .byte 00
40213e60: 08 90 fe 3f
40213e64: 10 90 fe 3f
40213e68: cc 24 00 40
It looks that even if OTA2 (user2.bin) firmware is running, something points to section in OTA1 and if user1.bin is not there, firmware will not run. Any idea what to check to fix this issue?
Rgds,
Frenk
Postby FrenkR » Fri Oct 07, 2022 2:06 am
If you don't do that, then uprading from app1 to app2 with the same bin will work, but if you will empty segment1, bin2 will stop working (which makes sense).
I hope that I saved 3 days of hard work "hunting" all those zillion of exceptions.
Rgds,
Frenk
Users browsing this forum: No registered users and 227 guests
